There seem to be two main popular O-rings used when you need to replace the O-ring on the DISA (common vacuum leak point).
I purchased both the Fel Pro gasket (PN 35489 for a 1991 to 1994 Ford Probe) at advanced auto for ~$7, and the german auto solutions O-ring (as part of my DISA repair kit).
I can say for sure that the Fel Pro gasket is nowhere near what the german auto solutions one was. I couldn't even tighten it all the way with the Fel Pro. Notice how it is thicker and has a smaller diameter.
If you need just the O-ring, the G.A.S is a no brainer:
https://www.germanautosolutions.com/...sa_o_rings.php
