I tried doing a video when I first got my Sprint Booster, it's really difficult to show the response time of the pedal vs Tach.
If the video can capture sound easily, then a tach view isn't needed. The sound would more than suffice to gauge the response.
If someone is able to do this, I would soooooo appreciate it!!
I just installed my PedalBox........I like it! I was one of those that was always a bit skeptical of the SprintBooster, thinking all you have to do is press the pedal farther if you want to go faster, but after reading so many of you say how much you liked the SB, I had to give it a try. It really does give the impression of more power and just so much quicker throttle response. I will take a bit of getting used to while going through the gears, I only went for a short drive so far. I can see myself using a bit more fuel, at least for a while until some of the novelty wears off. :-)
I do have one complaint though......they could have given you a little more cable to work with so you'd have more options on mounting the controller. It only reaches about to the shifter.
Barry
Bump...
Gary, I might be wrong but I think these throttle mod things could be a waste of money on an AT car.
Honestly it's one of the best Mods I have done to my AT ZHP. Several of us have done these but using the Sprint Booster with the Mode button "Version 2" and love it! John had William modify a Sprint Booster and integrate it into a Sport button panel and it's works great, see link below! You have 3 modes to select from at the center panel. William did one for my ZHP as well. It really makes the ZHP pedal feel like it should of from the factory, it took the delay out of the gas pedal.
http://www.zhpmafia.com/forums/showt...d-doityourself
A little over a year with it and still love it. I have one on the ZHP and one on the X5. The X5 I use economy mode, in that mode it seems to just effect the off idle response which is all I want on that car.
2006 CiC 6MT
ZHP, Cold Weather, Xenon
I have the SB on my STEP and absolutely love it, especially with the sport button mod.
Yesterday I went for ice cream with my daughter and for the first time I switched the Sprint Booster from Green to Off. What a difference!! The cars feels like it needs a major tune up. Back to Green.
