Results 1 to 4 of 4
    Apr 2011
    Dallas
    DSC diagnostic codes with ABS and brake warning lights: what to do next?
    Car: family member's 2002 325i, auto trans. 89k miles.
    Symptom: intermittent yellow brake and ABS warning lights in instrument cluster. They come on together, there is a single audible warning "gong" and while lit, the DSC doesn't work.
    Recent alignment did not solve the problem. Notable because some have cured this problem via alignment.
    Autologic diagnostic report: ABS/DSC: 5D8C can timeout; 5D97 voltage supply, both on DSC sensor.
    This ring any bells? New DSC unit is $$$ and therefore not looking to replace it unless I have no choice. Hoping it's something peripheral to the DSC unit.
    To any non-members who come across this thread and have the solution, please contact Mark at z1usa dot net.
    ND
    Usually I think the first thing to check is the abs/speed sensors at the wheels.
    http://forum.e46fanatics.com/showthread.php?t=697551
    More results.....
    https://www.google.com/search?hl=en&...w=1060&bih=466
    Oct 2011
    Silicon Valley
    My personal experience was that unbolting and cleaning each wheel speed sensor made my DSC light problem go away. It won't fix every problem, but it's the cheapest possible fix to try! Another cheap option if you have the coding setup is to re-calibrate the steering angle sensor, but I assume if that were the problem you would have seen a message about it in the AutoLogic printout.
  1. DSC + Orange Brake lights: Yaw sensor?
    By 2004_blue_zhp in forum Mechanical | Troubleshooting
    Last Post: 08-06-2016, 01:09 PM
  2. Brake and traction control lights on.
    By jjcools in forum Mechanical | Troubleshooting
    Last Post: 09-15-2011, 05:06 AM
  3. ABS ASC and BRAKE lights on!!
    By knosker in forum Mechanical | Troubleshooting
    Last Post: 06-29-2011, 07:30 AM
  4. DSC & BRAKE lights come on yellow
    By bmrhead in forum Mechanical | Troubleshooting
    Last Post: 06-28-2011, 05:47 PM
  5. Automatic Transmission and Yellow Brake Warning Lights In & Out. Meh.
    By billschusteriv in forum Mechanical | Troubleshooting
    Last Post: 06-28-2011, 11:54 AM
