Pretty pissed to find my OEM clear corner light fogged up with condensation.
Is there a way to dry the water out?
E92 335i M-Sport
997 S
This happened to me in the past. If you leave it out, it will dry. You'll likely need to replace them, unless you can find a way to replace the gaskets....
These are on ecstuning.com brand new for $80.
On the hunt for the cleanest lowest mileage ZHP sedan!
Mine are like that too :/
Check the gaskets on the turn signal sockets.
Sent from a junkyard via GS4.
In the market for an E90 M3
Let it dry then use some black silicone on the edges to "re-seal" it?
Something like this? http://www.amazon.com/gp/product/B00...1&s=automotive
Have my ugly ambers in now. Probably will end up buying new corners then selling my old ones on here.
E92 335i M-Sport
997 S
How long have you had those oem clears for?
trancenation's Alpine Weiss ZHP
I have/had the same issue. I drilled very small holes in the corner of each corner light on the side(unseen). I haven't had a problem since...
Sent from my iPad using Tapatalk - now Free
Ironically enough, there is no more condensation. Did nothing...it just dried up.
E92 335i M-Sport
997 S
