Page 1 of 3 123 LastLast
Results 1 to 10 of 28
    Bronx, New York
    problem with brake disc.
    I have my hand/emergency brakes on and my brake disc still moves. What do I need to solve this problem?
    I suck in this area. I don't want you to think I am ignoring you...cuz I'm not.
    Could it just be the brake shoes?
    You've done this...right?
    Pull up on the e-brake boot till it pops off. Then tighten the two cables with a wrench. Make sure the rear wheels still roll freely when the e-brake is off.
    Asheville, NC
    Would he just need to tighten the cable that is connected to the ebrake? Lovezhp, if you put the brakes on with your foot, do the pads engage? If they do, i would think either your cable from the ebrake is broken, or it needs to be tightened. Right guys?
    09 135i Msport 6mt
    04 330i ZHP (sold)
    David
    Bronx, New York
    Alright ill try to see if thats the problem im at home now and its late over here... Thanks a lot guys.. i Think its the ebrakes cable tho
    Bronx, New York
    I need a lesson on brakes. =/ i have no idea about senors and pads, rotors? ebrake line? can anyone explain? please.
    Western WI
    Time for a new e-brake shoe.
    Asheville, NC
    Yeah. Listen to mimalmo and dane. I know just enough to get u in trouble!
    Sent from my DROID2 GLOBAL using Tapatalk
    09 135i Msport 6mt
    04 330i ZHP (sold)
    David
    OK.....so here is a pic of your e brake system. The brakes on your lawn mower are probably bigger...
    IN A NUTSHELL
    Front and rear brakes are basically the same. Each system has a piston that is fed with brake fluid via a brake line. As you press on the brake....fluid pressure is sent down the brake line to the brake caliper piston. This will move the inner portion of the of the brake caliper and will squeeze the rotor between the two pads.....
    The outer brake pad and caliper portion are stationary. The caliper guide bushings are what keeps the inner moveable caliper and brake pad nice and parallel as you press the brake.
    SS brake lines are better because they don't "flex" under dynamic breaking...like the rubber ones do...therefore they are much more responsive.
    Also recognize...you have brake pad wear sensors on the front right and rear left brake pads.
    The rotor thickness spec is stamped onto the rotor hat should you ever need this info.
    Jan 2011
    Mass
    Quote Originally Posted by L0veZHP View Post
    maybe the shoes are worn or simply the cables need adjustment.
    easiest fix is the cable adjustment.
    2005 BMW 330i ZHP
    2004 BMW 330Ci ZHP A DIY Turbocharger Project!
    My site: www.E46Turbo330Ci.com
    http://www.zhpmafia.com/forums/image.php?type=sigpic&userid=545&dateline=1337626488
  1. The expansion tank problem - does it also apply to ZHPs?
    By Stu in forum General -- ZHP Related
    Last Post: 06-30-2011, 07:49 AM
  2. Problem with my Knob
    By pyreguy in forum Mechanical | Troubleshooting
    Last Post: 06-06-2011, 07:23 PM
  3. Transmission Problem?
    By vteckiller2000 in forum Mechanical | Troubleshooting
    Last Post: 04-01-2011, 07:20 AM
  4. I'm Not Sure, But This Might Mean That I Have A Problem...
    By kayger12 in forum General -- ZHP Related
    Last Post: 02-25-2011, 06:15 PM
