Well, they came. Seem to be good quality! Now how on earth do I install..
E92 335i M-Sport
997 S
I almost purchased a set of Weisslicht angel eyes but I felt their DIY was fairly extensive (but this will probably differ from your installation?). Feeling lazy didn't help either.
http://www.bimmian.com/elements/page...ht/PHO/PHO.pdf
Please update on how they fit! Are they fitted for xenons?
Sent from my SM-N900T using Tapatalk now Free
In the market for an E90 M3
I feel like I'm missing parts? Are there suppose to be ballasts?
E92 335i M-Sport
997 S
It looks like you may need a set of ballasts and a relayed wiring harness that has +12V, GND, and Trigger wire(s).
trancenation's Alpine Weiss ZHP
I called them earlier today they stated the 9600 relay would do the trick. I would say call and reconfirm.
http://www.theretrofitsource.com/pro...oducts_id=3182
Tony's ZHP "Wulf" '03 Silver Gray | Valentine 1 Radar Detector| Alcantara | BMW Performance Intake | F10 M5 Knob | Auto-dim Retrofit | BMW Alarm | Performance Grilles | OEM Roof Rack | Rain Light Sensor Retrofit | Eonon D5150 Head Unit | BMW OEM Clear Lens
Their ad says:
LEDs by nature do not need ballasts. Ballasts are for CCFLs. LEDs only require a current limiting resistor but those could be built into relays. The LEDS would likely require relays (is that what they are referring to as drivers?) to handle the current draw.Each kit includes 4 LED rings, input wiring/drivers and some mounting hardware/double sided tape.
The wiring just needs a 12V +/- input to power the rings, so the connections should be simple.
MiniD, what came in those small packets? Also, can you please measure the diameter of the rings? Are they flexible or rigid?
Should be getting mine today.
Just got mine. Going to be removing my bumper to repaint my lower grill and probably installing these today.
