Results 1 to 6 of 6
    Jul 2013
    Bend, OR
    Oil temperature drop?
    This morning I downshifted to 3rd, bringing the car to 3k rpms. Seconds later the display changes from time (what I always have it set to), to exterior temperature (37 degrees). The exterior temperature begins flashing and beeping. I was quite startled when I noticed that my oil temperature dropped by a quarter of an inch. In a matter of seconds the oil temperature returned to where it should be. The car was completely warmed up before I left my the driveway.
    What happened? Should I worry about it?
    -Dimitri; 19
    98 Dakar Yellow M3
    Recaro - Ground Control - Macht Schnell - AP - Mashaw - UUC - Schroth - Apex - TMS
    Aug 2011
    San Diego, CA
    What car do you drive? M3? I didn't think the ZHP had an oil gauge.
    The beep and 37 degree thing is standard and let's you know if might be icy out. Freaked me out the first time it happened.
    Jul 2013
    Bend, OR
    Quote Originally Posted by Pip View Post
    A zhp. I guess I'm just a noob then haha. I always thought the temperature gauge represented oil temperature.
    So it had nothing to do with the sudden drop in temperature?
    -Dimitri; 19
    98 Dakar Yellow M3
    We don't have oil temp on our car.
    Your coolant temp may have dropped but that would be T-Stat related.
    Sent from my S4 > Mason, OH
    Jan 2013
    Central California
    Yep, could simply indicate the t-stat opening with a really cold radiator which could make the temp gauge drop suddenly. This happening the same time as the 37 degree warning going off is only a coincidence.
    Cleveland/Dayton
    Yep, basically above sums it up.
    Unfortunately you should be lucky you have some sort of temp...I don't have any sensor gauge in the 1er
  1. Replies: 16
    Last Post: 02-24-2014, 09:14 AM
  2. Incorrect Exterior Temperature- A/C Not Working
    By edlvrt in forum Mechanical | Troubleshooting
    Last Post: 04-20-2013, 05:09 PM
  3. Cluster Temperature Reading
    Last Post: 01-15-2013, 12:21 PM
  4. Decreased Gas Mileage Due to Temperature
    By llll1l1ll in forum Mechanical | Troubleshooting
    Last Post: 07-09-2012, 09:22 AM
  5. Coolant Temperature Sensor
    By MiHiZHP in forum Mechanical | Troubleshooting
    Last Post: 10-31-2011, 05:42 AM
