Bought this car with 80k miles and it now has 90k. Maintenance records were scarce, so assume that none of the important preventative maintenance has been done (e.g., expansion tank). I have set aside resources ($$) to address the most important items, and will consider nice-to-do items if possible. I intend to use a nearby independent shop that is pretty honest, but I think they work best when given specific tasks, part numbers, etc. - i.e., they are good guys but I don't want to rely on them to suggest work or parts. For that, I trust and prefer the Mafia! I read through many threads here to learn more, the sticky on reliability and Words of Wisdom for New Guys were particularly helpful.
Here is what I have in mind so far, no particular order, so please comment, add or make suggestions on specific parts:
1. Cooling system overhaul - expansion tank, water pump (metal), water pump pulley, belts, t-stat, etc. - how about ECS Cooling System Refresh Kit Level 1? Any idea why their level 2 & 3 kits are only for <10/2002 production?
2. Normal Inspection 2 Service - oil, filters (oil, cabin, fuel, air) and spark plugs. ECS Inspection 2 kit ok?
3. DISA Valve - no rattling or rough/low idle, and no lean codes, so assume I am o.k. Will ask shop to inspect and confirm o.k.
4. Suspension - this is where I am most uninformed and could use the most help. I am not experiencing any problems, but then again, how would I know without a brand new set-up to compare? But at this mileage, I expect members can suggest specific parts to address either because they are due or on a preventative basis. Control arms? Bushings? What else? I am thinking maybe the ECS Level 1 Refresh kits for front and rear, plus I already have the reinforcement plates to install. If you have other ideas about specific parts and sources (OEM v. aftermarket), let me know.
5. Starter - I have posted elsewhere about inconsistent cranking, and expect I will need a new starter (battery is good and crank sensor was replaced...needlessly, as it turns out!). I intend to replace with OEM.
6. Transmission - oil and drain & fill plugs - ECS kit.
7. Differential - fluid, gaskets, seals - ECS service kit.
8. Pulleys & belts - recommended replacement in the Words of Wisdom for New Guys thread. Go with OEM for all? If I have funds, I might go with UUC underdrive pulleys.
9. CDV Delete - look forward to doing this!
Battery is good, and no vanos rattle so I don't anticipate doing anything with those. Nor am I planning to do the timing chain/tensioners.
Lastly, I am in Atlanta (Buckhead/Smyrna) so if anyone knows of a good shop with E46 expertise, I am open to suggestions. Otherwise I will stick my guy.
Thanks!!!
Edit: Should have posted this in Maintenance - Mods, feel free to tow it there! Sorry!
