Page 1 of 100 1231151 ... LastLast
Results 1 to 10 of 995
Thread: Imola Red Sedan Project/Maintenance Thread
    Well after a year of ownership, it was time to make an actual project thread for my not soo special ZHP.
    Purchase date: 11/1/2012
    Mileage: 89,975 upon pick-up in new Jersey
    Imola Red Exterior
    Alcantra Interior with black cube originally
    Heated seats but no rear fold seats
    Folder full of maintenance records including clutch, cooling system,filters etc.
    After having owned it for a year, I have greatly enjoyed the vehicle. Progress is slow in the mod department however I do have lots of plans for the car. Been mostly keeping up with maintenance and small repairs here and there.
    Current List includes:
    Dr.Vanos - Mileage 92,775 - Date 1/5/13
    NGK Spark plugs - Mileage 92,775 - Date 1/5/13
    OE BMW Valve cover gasket - Mileage 92,775 - Date 1/5/13
    OE BMW Valve cover seal gasket - Mileage 92,775 - Date 1/5/13
    UUC Poly Gen 2 Control Arm Bushings - Mileage 93,000 - Date 1/12/13
    UUC Stainles Steel Clutch line - Mileage 93,000 - Date 1/12/13
    OE BMW Oil Level Sensor - Mileage 93,000 - Date 1/12/13
    Oil Change Mobil 1 0W-40/ Mann Filter - Mileage 93,000 - Date 1/12/13
    Power Steering Reservoir Cap Seal - Mileage 93,000 - 1/12/13
    Clutch Delay Valve Delete - 1/12/13
    Khoalty LED License Plate Bulbs - 1/12/13
    Silver cube trim ( replaced black cube trim that the car came with ) - 7/15/13
    OE BMW Aux kit ( replaced factory ipod kit that the car came with ) - 7/15/13
    Akenobo Front Ceramic brake pads - Mileage 99,750 - 8/3/13
    OE BMW Short Center console with arm-rest delete and euro tray - 8/17/13
    OE BMW Front Lower Left Fender Liner and Brake Duct Bracket - 11/6/13
    Bridgestone Potenza S04 tires - Mileage 107,000 - 11/9/13
    Trans Fluid Drain and Refill with Redline 75W140NS Gear Oil and Redline Synthetic D4 ATF - Mileage 107,120 - 11/13/13
    Turner Motorsports Euro RCR Tails - 11/20/13
    Khoalty Chrome Rear Turn Signal Bulbs - 11/20/13
    ZIZA LED Interior Lighting Package Kit - 12/20/13
    OE BMW Performance Black Grills - 12/23/13
    OE BMW Oil Filter Housing Gasket - Mileage 109,125 - 1/4/14
    OE BMW Vanos Oil Line - Mileage 109,125 - 1/4/14
    OE BMW Hydraulic Belt Tensioner Assembly - Mileage 109,125 - 1/4/14
    OE BMW Belt Tensioner Pulley and Idler Puller - Mileage 109,125 - 1/4/14
    ZKW Clear Lens fog-lights and OE BMW foglight covers - 2/1/14
    Coby Wheel Steering Wheel with Black Alcantara/Tri-Stich/Red Time Stripe - 2/6/14
    Clutch Stop - 2/11/14
    OE BMW Front Plate Delete Strip - 3/22/14
    OE BMW hood emblem - 3/22/14
    OE BMW rear bumper diffuser - 3/22/14
    Bodywork and Paintwork on front end and rear bumper - 3/22/14
    Turner Motorsports Euro Front Corners/Side Markers - 4/3/14
    Khoalty Chrome Front Turn Signal Bulbs - 4/9/14
    AKG Steering Flex Shaft Coupling Poly 75D -Mileage 113,000 - 4/12/14
    OE BMW Rubber Floor Mat Set - 5/20/14
    OE BMW M3 Engine Mounts - Mileage 115,470 - 6/28/14
    OE BMW M3 Transmission Mounts - Mileage 115,470 - 6/28/14
    OE BMW Oil Pan Gasket - Mileage 115,470 - 6/28/14
    OE BMW Oil Dipstick O-Ring - Mileage 115,470 - 6/28/14
    Oil Change - Mobil 1 0W-40/Mann Filter - Mileage 115,470 - 6/28/14
    Power Steering Fluid - Drain/Refill with Redline Synthetic D4 ATF - Mileage 115,470 - 6/28/14
    Differential Fluid - Drain/Refill with Redline - Mileage 115,470 - 6/28/14
    Mann Intake Air Filter - Mileage 115,470 - 6/28/14
    Mann Cabin Air Filter - Mileage 115,780 - 7/11/14
    Gominigo No LPB Kit - 7/15/14
    Coby Wheel Shift boot / Handbrake boot with Black Alcantara/ Red and Blue Stitching - 12/25/14
    Oil Change - Mobil 1 0W-40/Mann Filter - Mileage 123,688 - 3/21/15
    Power Steering Reservoir Cap Seal - Mileage 123,688 - 3/21/15
    Takata Passenger side airbag recall - Mileage 126,217 - 6/6/15
    Coding includes following items: Mileage 126,995 - 6/22/15
    1) comfort open/comfort close
    2) clown nose blinks
    3) coolant temp gauge calibration
    4) speedometer calibration
    OE BMW LCM with 4.5 Software with coding for following items - Mileage 127,062 - 6/25/15
    1) triple blink
    2) tri-fecta lights
    3) brake force display stage 3
    4) euro rear fogs (both inner lights)
    5) euro hazards
    Siemens/VDO Fuel Pump Assembly - Mileage 127,062 - 6/25/15
    Bodywork and Paintwork on front bumper and FR fender - 6/25/15
    OE BMW Fuel Pump Gasket - Mileage 127,875 - 7/14/15
    OE BMW M3 Fuel Pump Baffle - Mileage 127,875 - 7/14/15
    Rust repair and paintwork on RR Quarter Panel - Mileage 128,300 - 7/25/15
    Bridgestone Potenza S04 Rear tires - Mileage 128,349 - Date 7/30/15
    OE BMW ZHP Shift Knob - Mileage 128,349 - Date 7/30/15
    OE BMW lower steering wheel trim - Mileage 129,361 - Date 8/10/15
    Oil Change - Mobil 1 0W-40/Mann Filter - Mileage 129,456 - 8/13/15
    Mann Intake Air Filter - Mileage 129,456 - 8/13/15
    Mann Cabin Air Filter - Mileage 129,456 - 8/13/15
    OE BMW Left/Right Front Bumper trim - Mileage - 132,316 - 10/2/15
    OE BMW Wiper Blade Set - Mileage 132,613 - 10/13/15
    OE BMW A-pillars with inserts - Mileage 132,613 - 10/13/15
    OE BMW Windshield Cowl - Mileage 133,158 -10/29/15
    German Auto Solutions 1.2 Bar Coolant Cap - Mileage 135,607 - 1/11/16
    Passenger Seat Occupancy Mat Bypass Module - Mileage 135,976 - 1/27/16
    Oil Change - Mobil 1 0W-40/Mann Filter - Mileage 138,343 - 4/23/16
    Clean Throttle Body and IACV - Mileage 139,230 - 5/14/16
    OE BMW Throttle Body Gasket and IACV Grommet - Mileage 139,230 - 5/14/16
    OE BMW Upper/Lower Intake Boots - Mileage 139,230 - 5/14/16
    Fuel Filter Mahle Filter - Mileage 139,361 - 5/19/16
    German Auto Solutions DISA Rebuild Kit - Mileage 139,389 - 5/21/2016
    Redline SI-1 Complete Fuel System Cleaner - Mileage 143,650 - 12/4/2016
    Oil Change - Liqui Moly 5W-30/Mann Filter - Mileage 145,398 - 2/20/2017
    Liqui Moly MOs2 Anti-Friction Engine Treatment - Mileage 145,398 - 2/20/2017
    Liqui Moly Jectron Fuel Injection Cleaner - Mileage 145,398 - 2/20/2017
    Intake Air Filter Mann Filter - Mileage 145,398 - 2/20/2017
    Cabin Air Filter Mann Filter - Mileage 145,398 - 2/20/2017
    Differential Fluid - Drain/Refill with Redline 75w90 - Mileage 146,030 - 5/13/2017
    Transmission Fluid - Drain/Refill with Redline D4 ATF - Mileage 146,030 - 5/13/2017
    Full Set of Tires - Hankook Ventus v12 evo2 - Mileage 146,030 - 6/10/2017
    OE BMW M3 front strut bar ( Previous Owner had installed )
    Turner Motorsports Clutch Kit ( Previous Owner had installed )
    And plenty more stuff to come
    Images from my trusty cell-phone
    Somewhere in PA filling her up for the first time
    Rolling over to 90k
    The ZHP meets the maxima. Sold the maxima and do miss that car. It had wheels,coilovers and exhaust on it
    Random shot at a local warehouse
    First Camping trip with the ZHP
    And then that 100k magic number
    Silver cube and the short console with euro tray
    Getting New tires installed
    Jul 2011
    Long island, New York
    Beautiful car. Subscribed.
    Sacramento, CA
    What took so long, Vas? Camping pictures looks great. I haven't gone camping in a while... not since Skala in 2010 or 2011. Gotta go next summer!
    2003 Oxford Green ZSP 5MT 330i
    "I thought you were the car whisperer, Dario." -johnrando
    I remember skala camping trips. Those were great and a beautiful place.
    As far a thread, I usually mods cars as a fairly decent pace so there are constant updates. With buying a house money is tight and is more focused on upkeep of the car.
    Sep 2011
    San Francisco, CA
    'Bout time Vas. I love the armrest-less center console look.
    Lebanon, OH
    Quote Originally Posted by derbo View Post
    No gangsta lean tho.
    Sent from my S4 > Mason, OH
    "Flame suit NOT REQUIRED!!!"
    Sep 2011
    San Francisco, CA
    Dont need no armrest for them Gansta LeanZ
    Lebanon, OH
    Lol guys.
    Sometimes I do miss the armrest for storing stuff but the majority of the time it got in the way for me.
  1. Charlie's ///M Project Thread
    By cakM3 in forum Projects
    Last Post: 10-14-2020, 08:13 PM
  2. Replies: 594
  3. Gr's Imola Project
    By gr330zhp in forum Projects
    Last Post: 08-26-2013, 01:36 PM
  4. Silvergray ZHP Project Thread
    By MiniD in forum Projects
    Last Post: 05-23-2013, 03:50 PM
  5. Weekend's ZHP Maintenance/Upgrade Project
    By VaTechZHP in forum Maintenance
    Last Post: 03-11-2012, 05:27 PM
