Not following you a 100%. Mind explaining?
All the led bulbs turn on and off and the dome light plus c-pillars still fade in and out when the car is unlocked/locked for me.
Also looked through my paperwork from the previous owners and no sign of the ofgh being replaced. Car has 108k on it so i ordered a new gasket, Vanos line and washers.
Last year during the winter I was doing Vanos,plugs and valve cover gasket.
Dumb question but are you sure the polarity is correct when you put the led bulb with the socket back into the light?
After talking to Dario and looking through my service records that I have from the previous owner, it looks like the idler and the belt tension pulley were never replaced. Since I am going to be in there replacing the ofhg, might as well as replace these parts as well.
But according to records, the water pump pulley and belts were replaced with oem parts about 30k ago. And I was thinking about the hydraulic tensioner but decided not to get it. If it is bad upon inspection, then I will replace it. So skipped those items.
On order are the two pulleys, bolts and caps.
Ha, I hope you don't end up finding out your tensioner is bad at 8:00pm like me! Thank goodness I had a parts car, or else my car would still be gutted.
In the market for an E90 M3
Hers: 04 330i ZSP
ECStuning actually has a sale on them sometimes so it was roughly $65 for the complete interior kit. Plus they offered free shipping on them.
Biggest benefit is that they provide a higher light output. Plus the light output is white and crisp instead of the dull yellow from regular bulbs.
Not a bad deal on sale. I like the look inside at night with them. Remember the bulbs only work if installed in the correct direction (polarity). Hope they last a good long while.
