Results 1 to 5 of 5
Thread: ABS sensor info - I need some help
    Long time lurker, first time poster. I currently have a turbo e36 M3 and I'm looking to get into a ZHP in the near future (most likely a 2004-2005 sedan).
    I plan to turbo the ZHP as well and have a question about the stock ABS sesnors. I want to transfer my Racelogic Traction Control unit from the e36 to the e46, but the ABS sensors on the e46 are CAN-based and not compatible with the RLTC unit I have. I am interested in buying an electronic "conversion box" that can read the BMW signal and transfer it to something the RLTC can understand.
    Does anyone have info about the signal the e46 sensors produce? I believe they output a digital square wave (not a traditional analog voltage) that is then read by the DSC. Here is some literature on the web that talks about DSC/wheel speed sensors: http://www.kneb.net/bmw/E46/04%20E46...%201-27-03.pdf
    But I am not sure if this document covers the ABS system in the ZHP since it appears to be written in the 2001-2002 timeframe. Does anyone know if all 4 ABS sensors are 2-pin or 3-pin connections? I believe they are either the "active" or Magneto-Resistive(see page 18-19 in the .pdf), but I would love someone to verify that for me.
    Does the ZHP use the MK20 or MK60 DSC system?
    Thank you for any help you can lend!
    Sep 2011
    San Francisco, CA
    ZHP uses MK60. It uses the magento-resistive ones. If you want to check, you can see if has a blue plug on the abs sensors wire not the grey wire.
    Fronts should be a 3-wire (extra ground point) and the Rear is a 2-wire.
    Quote Originally Posted by derbo View Post
    Excellent - thank you!
    If you haven't done so, please feel free to introduce yourself and your car in our new members section. GL w/your future project.
    ZHP Performance Package, Cold Weather Package, Leather, Jet Black/Black/BlackCube, NAV
    ESS Stage 1 Twin Screw Supercharger, Sprint Booster, BMW Perf Intake, Magnaflow Exhaust, Dinan TB & STEP S/W, Ground Control Coilovers, UCC Sway Bars, Apex EC-7 18x8.5 ET38
    Thank you for the warm welcome John! I'll be sure to officially introduce myself (and my car) when I finally purchase a ZHP. But until that happens, I need to ask for some more help with the ABS sensors.
    Does anyone have access to an oscilloscope and willing to probe a front and rear sensor and email me the screen shots? I want to verify the signal looks as expected before I commit to the 'conversion box'. I would be more than happy to compensate you for your time if you can provide me with this info. Thanks guys!
  1. Detailing info..
    By BimmerWill in forum Detailing
    Last Post: 10-18-2012, 07:17 AM
  2. Transmission Plug Info
    By deuce08s in forum Maintenance
    Last Post: 07-19-2012, 01:17 PM
  3. Track Wheel Info
    By RyanOsiecki in forum Track and AutoX
    Last Post: 04-13-2011, 05:51 PM
  4. Moar BMW 330 ZHP info....
    By danewilson77 in forum General -- ZHP Related
    Last Post: 11-25-2010, 08:14 AM
