Gregory Maguires not a bad author, either. He hooked me with Confessions of an Ugly Stepsister, a revisionist version of a rather saccharine old fairy tale. Fun!
I saw some wheels for sale that I liked, but I don't know the first thing about offset, ET, whatever. Will these fit a stock ZHP set up? (but likely going to H&R springs with Biltsteins). I'm guessing maybe a fender roll would be needed? Anything I'm missing, I'm a total noobie when it comes to wheels.
19x8.5 +37 front and 19x9.5 +35 rear
Run a 255/30/19 rear and roll the fenders. Front fits no problem with a 225/35/19
Thanks Eli!
If I make my rear wheels 10mm out from +45 original, how much fender roll do I need? I rolled them but I guess not enough...LOL. Does ET35 just require a ton more modification? I don't want this to be a huge project...but I do love the 35 look as long as I can drive quickly and corner fast with a load...if I can't do it then I won't do it. I need low and quick, not low and slow. LOL
--Trevor--
Vancouver, BC
IIRC Trevor, you have some fairly wide tires out back so you'll need to get the fenders rolled as flat as possible.
I was so scared of losing that vertical crease as I rolled the inside lip. I didn't want to create a bulge that looked nasty. What's the secret? I was using the official bolt to the hub roller along with a heat gun and a friend pressing on the outside of the paint as the roller pressed against the inside.
--Trevor--
Vancouver, BC
I'm looking for a lightweight wheel to use for the winter time. Would refinish them black. It shows up as one of the wheels available for the 2004 330Ci on RealOEM.
They need to be refinished, the guy is asking $250 for them with trashed tires. Fair price? I was thinking $200 if he pulls the tires first.
2004 Alpinweiss 330Ci ZHP 6MT
Yes.
If you have a 330i...thay have to be 17" I believe.
I am not sure if Style 44's came in a size and offset other than what was offered on the 2004 330Ci (8JX17 ET:47).
If they are the same part number (36111094506) - some part of which should be stamped/cast on the back... then they should fit... I would just confirm the size and offset is as expected.
