Hi All,
I've been trying to troubleshoot this problem and have been checking this forum as well as others to find a solution. So far no luck.
Symptoms: Driver Side Headlight Low Beams not working, but passenger side works.
Troubleshooting:
1. Swapped bulbs with other side (confirmed working)
2. Swapped ignitor with other side (confirmed working)
3. Swapped ballast with other side (confirmed working)
4. Checked battery voltage w/ OBC menu on dash. ~124 w/ car off and ~147 w/ car on
** Crazy thing that happens is if I completely Disconnect the passenger side power connections to the bulbs, the driver side will come on after a second when I turn the headlights on.
Should I reseat the battery power connections, even though the voltage is reading right?
Do the Bi-Xenon's have a fuse? (I read somewhere it doesn't)
Is there a Relay somewhere that I can't find?
Anyhelp would be appreciated.
Thanks!
