Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
    Apr 2012
    Jupiter, FL
    FWIW, I've swapped to SS brake lines on two ZHPs now and honestly, I can't really feel much of an improvement. So, if you want to save the $125 or whatever they cost, then don't bother. A good flush and proper bleed (as stated above a few times) will be your biggest help. I too recently flushed to the ATE Type 200 fluid.
    Also, this time when I flushed/bled, I hooked the car up to INPA and ran through the ABS functions to activate and ensure all of that was bled/flushed as well. Seemed to help with a nice stiff pedal...
    Nov 2013
    Bay Area
    Quote Originally Posted by JupiterBMW View Post
    1.) do you track/autocross?
    2.) I was under the impression the rubber hoses wear out. Is that not true/over stated?
    3.) do you have a suggestion on alternatives? I don't wanna cheap out on any part of the brakes, but OEM lines are about $40 each.
    Hers: 04 330i ZSP
    Dec 2010
    Fairfax Station, VA
    Quote Originally Posted by Dave1027 View Post
    I've replaced brake fluid on vehicles because it was dark. By the next day it was dark again and I never noticed any change in brake feel. Felt like a waste of time.
    If this happens, it means your rubber brake lines are deteriorating from the inside out, their inner rubber lining is disintegrating very time you push the brakes. If you see dark after a brake flush, then you need to replace your brake lines, OEM or SS is your choice.
    Bruce
    21 GMC Sierra - mine
    16 X5 M-Sport - wife
    11 M3 - 1st son
    04 Tundra - 2nd son
    17 X1 M-Sport - daughter
    Former (mo/yr sold):
    15 335xi M-Sport (8/18)
    11 335is (8/17)
    11 X5 AW/blk (11/15)
    04 330xi blk/gray (7/15)
    06 ZHP SGM/blk (6/15)
    08 335xi blue/blk (4/15)
    04 ZHPci MB/blk (2/14)
    04 ZHPcic IR/Alc (10/13)
    01 540iT anthra/blk (7/13)
    04 ZHPci TIAG/blk (9/12)
    03 540i M-Sport (9/12)
    01 325ci (3/12)
    02 325iT 5MT (10/11)
    05 ZHPci (7/11)
    03 330cic (2/11)
    00 323ci (10/10)
  1. Mixing Brake Fluid
    By llll1l1ll in forum Brakes
    Last Post: 02-23-2014, 04:51 PM
  2. What brake fluid do you use?
    By ryankokesh in forum Maintenance
    Last Post: 09-26-2013, 10:07 AM
  3. QUESTION: Brake Fluid
    By Stigissimo in forum Maintenance
    Last Post: 06-19-2013, 11:13 AM
  4. ATE brake fluid in San Diego
    By blablac in forum California
    Last Post: 11-23-2011, 05:37 PM
