Results 1 to 10 of 14
    Engine hot but temp gauge is perfect
    My ZHP has 96k. Temp gauge is straight up at 12:00 o'clock. It seems though the engine is getting too hot. It smells hot and I can feel heat coming from the engine bay that can't be normal.
    I will do a cooling system update for all components in two months. Stewart water pump, radiator, pulleys, belts, tensioners, hoses, BMW coolant, thermostat, bolts fan switch, but not the fan. If after all this, then maybe the fan too.
    Will be using ECS and Bavauto mainly.
    For those of you that have experienced this, what is your advice?
    Vancouver, Canada
    Don't trust the temp gauge. The computer keeps it at 12 o'clock over a wide range of temperatures. I have an ultragauge which reads the raw temp data thru the obd2 port and shows you the real temperature.
    Sent from my Galaxy Nexus using Tapatalk
    __________________________________________________
    2008 128i ZSP Sedonarot
    2004 330i ZHP Imolarot
    Conforti Shark Injector - Installation Pending!
    AFE Magnum FORCE Stage 1 PRO 5R Intake
    ECS Tuning Strut Bar
    ECS Tuning Magnetic Drain Plug
    German Auto Solutions DISA Gold Valve
    CDV Delete
    BSW and Polk Drivers
    Ziza LED Interior Kit
    Khoalty CREE LED Reverse Lights
    BMW strut tower reinforcement plates
    Vancouver, Canada
    Quote Originally Posted by Stewbie View Post
    Ignore double post. Still getting used to Tapatalk.
    CDV Delete
    Aug 2011
    Las Vegas, NV
    X2...
    UltraGauge Info in my sig.
    Apr 2012
    Long Beach, CA
    You have a few options. Easiest thing is to do a YouTube search for how to access the hidden guage menu. There you will be able to see how hot your car is running in Celsius. It should be around 94-96.
    Second option, and something you should plan on doing, is going into the coding section and reading my thread about how to reprogram your temp gauge so it's actually useful.
    Jan 2014
    Lincoln,NE
    If you are at 94-98 C you are fine. Plastic gets hot.
    2005 BMW 330i ZHP A08
    Dinan Stage 1
    ~ Garry Murphy
    Lexington, KY
    What does your on board computer tell you?
    Oct 2011
    Silicon Valley
    My engine compartment always smells "hot" after it's run and the beauty covers are too hot for me to keep my hand on them for more than a few seconds. But never smells like something is burning, except before I fixed the valve cover gasket--back then there was a burning oil smell as oil dripped onto the exhaust manifold. I believe I have a very slow coolant leak from one of the plastic coolant pipes and that contributes to the "hot" smell.
    You could get a thermometer and try to measure the temp of both radiator hoses and compare it to what the OBC display says. With thermostat closed, one should warm up a lot more than the other, and after the thermostat opens the cooler one will catch up but should stay cooler than the hot one. The temp of the lower radiator hose may not match OBC display exactly, as I think the coolant temp sensor for the OBC is different from the fan switch temp sensor in the lower radiator hose.
    My infrared thermometer shows the coolant hose coming into the radiator at 186, and leaving gong back to the engine at 154.
    The thermostat housing is 175.
    The oil filter canister is 200.
  1. PA SOFT: How to reprogram our temp gauge
    By NorCalZman in forum BMW Coding
    Last Post: 05-21-2017, 09:14 AM
  2. Temp Gauge Not Working
    By webster in forum Mechanical | Troubleshooting
    Last Post: 11-13-2012, 08:52 AM
  3. My MPG gauge died
    By kpro in forum Mechanical | Troubleshooting
    Last Post: 05-13-2011, 04:57 PM
