Great idea.
BTW, is it hard to remove the retaining hex screw? I usually have to use Impact Driver to remove them on Honda rotors so I was wondering if I need to do the same?
Can be if it's rusted a little. Some have broken or stripped them and had to drill them out. I had a little trouble getting them out but don't drive on salted roads. I put anti-seize on the screws now--somebody also sells stainless steel versions of the screw.
Thanks for the heads up. I'll have my Impact driver ready when the time comes.
John,
Do you think centering all of that force on the bearing, can be detrimental to it?
Yep. You are correct.
