Results 1 to 9 of 9
    Mar 2014
    Los Angeles, CA
    Starting hesitation (suspected fuel system issue)
    I get this problem about 20% of the time. I'll turn the key, it'll crank just fine (no slow crank/battery issues) and then die out for a split second, and then start right up. It's almost like it's hesitating between dying out and starting up. If in the event it does die out, it starts up instantly on the second crank.
    I don't think it's a starter issue (it was replaced in the last 2 years). I thought it could be the battery but I'm not experiencing slow crank. One of the fuel injectors was replaced recently. I'm thinking it could be the fuel filter, which has no record of being replaced.
    I do smell fuel when I start the car but it's not particularly pungent. I kind of just catch a whiff when I reverse out of my parking spot. Treating my fuel system with the Chevron fuel system cleaner has helped somewhat, but not much.
    Any ideas? I could try to record a soundclip if that helps.
    2005 330Ci Sparkling Graphite AT
    Salt Lake City, UT
    Fuel pump relay. It can soft fail and work intermittently
    In the market for an E90 M3
    Vacuum leak. Do you have any other weird idle issues or performance issues?
    Valparaiso, IN
    Quote Originally Posted by Avetiso View Post
    You can do a quick test by switching the horn relay with the fuel pump relay and see if it helps. Diagrams
    Mar 2014
    Los Angeles, CA
    Didn't consider a vacuum leak. I don't get any hesitation/misfiring/codes, but when my car starts "with hesitation" as described above, it idles at 1000rpm for a min or two before dipping down to 600. If it starts normally (80% of the time), it idles at 600 from the get go.
    I will read more on the fuel pump relay. Don't know much about it but it sounds like a good place to start.
    Valparaiso, IN
    If your fuel filter hasn't been replaced yet, I'd do that too whether it's causing your problem or not.
    Sent from my iPhone
    No SES light?
    Mar 2014
    Los Angeles, CA
    No lights. And yeah, I'm going to do the fuel filter soon.
    Indy
    OP, did you ever figure this one out?
    This sounds similar to an issue that I'm having.
    BMW CCA # 510252
  1. *Request Thread* Need Pics of the Fuel Lines into the Fuel Filter
    By Hornung418 in forum General -- ZHP Related
    Last Post: 11-11-2012, 04:55 AM
  2. Fuel system issue
    By knosker in forum Mechanical | Troubleshooting
    Last Post: 05-27-2012, 10:47 AM
  3. Cooling System, Fuel Pump, CABs Done
    By echo46 in forum Maintenance
    Last Post: 08-08-2011, 11:18 AM
  4. Slight stutter/hesitation when cold starting car after aFE intake install
    By GreenFrog in forum Mechanical | Troubleshooting
    Last Post: 08-08-2011, 09:48 AM
  5. Post cooling system overhaul issue
    By SC4ME in forum Mechanical | Troubleshooting
    Last Post: 07-05-2011, 07:28 AM
