Am I doing this right? Or am I an idiot?
-Dimitri; 19
98 Dakar Yellow M3Recaro - Ground Control - Macht Schnell - AP - Mashaw - UUC - Schroth - Apex - TMS
Do I need the extra washer between the hat and mount?
-Dimitri; 19
Should be a washer between the top of the coil and the bottom of strut mount.
Then you should have a lock washer or nylock on top.
Looks good except you need to drop it
How do I tighten this 21mm nut on the top?
-Dimitri; 19
I think you need an air gun/wrench.
Or try vise grips with a socket. I think that worked for me. (#21) http://www.badenscarpages.ca/e46-sho...t-replacement/
Hmmm, I ended up using vice grips, but in a different way. Got it done though.
-Dimitri; 19
Sweet. I use vice grips as far up as on the coilover shaft as I can get it. Then I use my impact, but you can use a socket as mentioned.
