Results 1 to 8 of 8
    Jan 2014
    Racine,WI
    Transmission fluid and differential problems
    Okay so I went to change my MT with MTL and Im pretty sure these aren't the original bolts correct? Since there HEX bolts? Anyone know what size they might be? I also have differential fluid i plan to be replace but wasn't planning on doing it tonight and noticed a leak....great....I just read that sometimes just tightening the bolts works has this worked for anyone? Either way Im going to buy new bolts for the transmission fill and drain plug. For the differential I'm going to buy new drain and fill plugs and gaskets.
    Long story short just confirming that these are in fact not the original transmission drain and fill plugs. Also what are peoples experience with differential leaks?
    Salt Lake City, UT
    Mine were hex bolts. Original.
    In the market for an E90 M3
    Jan 2014
    Racine,WI
    Quote Originally Posted by Avetiso View Post
    Weird every DIY I've seen they say 17mm bolts
    Hex. Those are correct.
    Oct 2011
    Silicon Valley
    Those look like originals to me! I broke one my first time and had to buy a generic transmission plug and use it for a few years. I think it was a M18 plug. Worked fine but stuck out an extra 6 or 7mm.
    They don't sell the gaskets for the diff cover any more--you're supposed to seal it with RTV.
    Jan 2014
    Racine,WI
    What size are the drain and fill plugs?
    Oct 2011
    Silicon Valley
    The tranny drain and fill plugs are the same. I think the proper socket is an 8mm hex. The diff plug uses either a 14mm or 17mm hex socket.
  1. Transmission Fluid and Rear Differental Fluid capacities
    By echo46 in forum General -- ZHP Related
    Last Post: 05-03-2015, 08:06 AM
  2. Transmission and Differential fill methods
    Last Post: 04-09-2012, 11:05 AM
  3. Transmission fluid?
    By cparker in forum Maintenance
    Last Post: 03-27-2012, 03:20 PM
  4. Changed transmission and differential fluid
    By variate in forum General -- ZHP Related
    Last Post: 12-03-2011, 10:18 AM
  5. Possible Transmission Problems!? Please HELP!!
    By lilcdkey in forum Mechanical | Troubleshooting
    Last Post: 05-10-2011, 06:24 AM
