we need THIS
No, you need the CTPPAR007, for radios that have the round pins.
The 008 is for radios that have the flat pins, which is typically euro-only radios.
Alongside that, obviously, you'd need the Parrot CK3000.
Everything you need to know: http://www.bokchoys.com/differential..._bluetooth.htm
Right. I was Watching this auction and it ended and routed me to the 008...
This ebay auction looks cheaper than the last one.
that one says only up to 2001 model year as well....is that just a mistake?
That I do not know. I was just going by the part number that Spencer provided earlier. Perhaps Spencer can chime in.
Well, if the picture is to be believed it should work as it has the 17 round pin harness. The description also specifies a 17-pin connection, so it looks to be the right one.
Looking into adding BT to my '03 with Nav and the following delmarco DIY's clarify the discrepancies above re part numbers, model years, connector types, etc.:
If you do NOT have Nav:
http://forum.e46fanatics.com/showthread.php?t=720922
If you DO have BMW MkIV Nav (the factory-installed Nav type any ZHP would have):
http://www.e46fanatics.com/forum/sho...d.php?t=797072
