Good view here.
I agree with the comments above. Basically the weak point in E46 cars is the cooling system. If you can't confirm it's been maintained then address it. The ET is a common failure but I would also replace all the hoses and belts at this time. Since you are in there and flushing the coolant anyway. Especially if you have to do the water pump. IIRC the recommended water pump service interval is 60k or 75k.
Easy 3-6 hour job depending on experience. Don't forget to bleed the air out of the system when done.
t.
