Results 1 to 10 of 13
    Mar 2014
    Houston, TX
    Wheel stud conversion doityourself
    I don't think anyone has done a DIY for the wheel stud conversion. So here goes.
    Items needed:
    -Torque Wrench
    -5mm Allen head socket
    -Threadlocker (red high strength Loctite Brand)
    -Impact (mine is electric)
    -Brake Cleaner
    -Shop towels (disposable)
    Here's the steps
    -Call Ray and order your studs (Plug)
    -Remove Wheel
    -Clean out Bolt Holes
    -Dab a drop or two of Threadlocker on the short thread end of the stud
    -Torque down stud to 25 ft/lbs and repeat process
    -Install wheels and torque down nuts as you would the wheel bolts.
    -Repeat steps for all 4 wheels.
    -Step back and enjoy your work.
    My 7 year itch.
    Mods: BimmerBrakes Headers, Magnaflow full system, BYS Cross Drilled and Slotted Rotors, Hawk HPS Pads, Racing Dynamics Intake, Dinan Throttle Body, Bavarian Auto Short Shifter, ECS Tuning Strut Bar, Projector Fogs, Blackout Grilles, Euro Smoked Tail Lights, Black Corner Lights.
    Upcoming: Coil Overs, Sway Bars, Polyurethane Bushings all around, M3 motor mounts
    Nice beckel. Thanks.
    No flame suit required!
    Mar 2014
    Houston, TX
    Thanks buddy. I thought this might help
    My 7 year itch.
    VA/DC
    Sep 2011
    San Francisco, CA
    Great writeup!
    The double nut method is an alternative option and the only option for those with bullet-nose ends instead of allen-wrench ends.
    Jun 2012
    Socal
    you should add which thread locker you used. since there are a lot of red ones and some of them don't hold up over time in my experience. also you should let it cure 24 hours.
    Mar 2014
    Houston, TX
    Quote Originally Posted by sillieidiot View Post
    Good point, I used high strength (permanent) red. Loctite brand. I've always had good luck with Loctite brand. Fixed it above.
    Thanks for the kind words fellas!
    My 7 year itch.
    Jan 2013
    Houston
    sweet will do !!! future plans
  1. Replies: 31
    Last Post: 02-24-2016, 07:24 PM
  2. Wheel STUD CONVERSION
    By Smilez in forum BrakeYourSelf.com
    Last Post: 09-21-2015, 08:18 AM
  3. Replies: 28
    Last Post: 08-28-2014, 07:26 AM
  4. Lug Bolt>Lug Stud DIY doityourself
    By GMATT in forum DIY
    Last Post: 11-23-2011, 02:32 PM
  5. Replies: 12
    Last Post: 11-13-2011, 04:37 PM
