busted leveling switch in expansion tank - problem?
So last night I fired up the heater in my ZHP, a very rare occurrence. Moments later, my coolant level idiot light came on. This happened a couple of summers ago out of the blue. I topped up with a bit of distilled water, haven't seen any light since.. till last night.
So tonight I check the coolant level, sure enough it's low, and I added about 10-15 ounces of distilled water, till the float switch thing popped up (#5 in the diagram below).
But then the cap wouldn't go back onto the expansion tank, as if it were hanging up on something. Took it back off, found this at the bottom of the filler neck...
That piece had busted off. I managed to fish it out of the bottom (wasn't easy!) and get the tank closed properly. Do I need to be concerned about replacing the thing right away? It's not an expensive part, and part of it is still attached, but not sure if I need to deal with it immediately or not. Advice?
'21 M2 Competition
'08 Z4 M Coupé
'19 Golf R
