Results 1 to 10 of 16
    Beaverton, OR
    Oil Filter Housing - Has anyone done it?
    I've had a pretty nasty oil leak for some time now, at least a quart a month and I don't drive much. I figured out it was the oil filter housing/gasket, which apparently is pretty common, per my local BMW shop. I'm putting in a new radiator this weekend (which hopefully won't be too bad...), so I figured what better time to tear into the oil filter housing leak issue, than when I'll have a ton of room to do it! Has anyone done this repair before? The housing itself is ~$200+, but I don't think I actually need the whole housing, only the small inner gasket...which is $4.85. My BMW shop said something about the flange that butts against the block possibly warping, so it's best to replace the housing as well. However, their job is also to make $$$, so I don't see that being the case. Any tips on the job itself or the housing vs gasket replacement would be great
    http://www.ecstuning.com/BMW-E46-330...13838/ES23884/
    http://www.ecstuning.com/BMW-E46-330...19855/ES23900/
    2016 BMW M340i
    2013 BMW X5 M-Sport - Sold
    2009 550i M-Sport - Sold
    2006 650i Vert - Sold
    2004 330i ZHP - Dead
    2001 330i Sport - Sold
    2004 330i ZHP - Sold
    1999 E36 M3 - Sold
    Aug 2011
    Las Vegas, NV
    Mine was leaking really bad when I bought my car. BMW wanted $985 to replaced the entire OFH! I replaced the gasket/oring for $7 and no more leak. That was 2 years ago. No need to buy the housing.
    VA/DC
    Yes, not a bod job. Lot's of other things to do "while you're in there"--Clean ICV, DISA, throttle body, etc. Upper and lower intake boots?
    http://forum.e46fanatics.com/showthread.php?t=659100
    Replace the gasket. Not a bad job to do at all.
    Beaverton, OR
    Ahhh, that is music to my ears, thanks for the quick replies gentlemen! I'll be so happy to get this all cleaned up, once and for all
    Awesome DIY and pics, thanks for the link ELCID86!! Not a bad idea to take care of some of these too (Clean ICV, DISA, throttle body)
    2016 BMW M340i
    1999 E36 M3 - Sold
    Oct 2011
    Silicon Valley
    If you need to do the CCV, that's a good one. I did my CCV several months ago, and doing CCV with both OFHG and intake manifold in place is a big PITA. Would have been much easier with OFHG removed or leaning to the side. Good time to replace VANOS oil line if it's leaking, since you have to disconnect at least one end of it.
    It is a good time to inspect and clean DISA, throttle body, IACV, and intake boots, but I don't think you have to remove any of those to do the OFHG, so it's not mandatory.
    In my case tightening the 6 OFH bolts to spec still allowed a leak but I tightened them down extra and the leak stopped. I think the spec was about 14 foot-lbs and I tightened the bolts to 20 foot-lbs, but check the torque spec, as you don't want to risk stripped holes in the block. I did my OFHG 3 or 4 years ago and a recent check showed it might have one really slow leak now, but not nearly as bad as it was when I replaced it.
    Beaverton, OR
    So many acronyms, makes a guy feel like noob haha... Are there any good DIY's, or do's & don'ts for how to "clean" each of these valves/parts? Any chance you have the part# or RealOEM page for the Vanos oil line?
    Luckily I was able to google the DISA & IACV, and it looks like there are some youtube vids about them.
    2016 BMW M340i
    1999 E36 M3 - Sold
    Beaverton, OR
    Quote Originally Posted by LivesNearCostco View Post
    Is this the Vanos oil line you were referring to?
    http://www.ecstuning.com/BMW-E46-330...Vanos/ES23138/
    2016 BMW M340i
    1999 E36 M3 - Sold
    That is the vanos line.
    When I did my gasket, I replaced the vanos line and both pulleys.
    Sep 2014
    Mountain View, CA
    While the alternator was removed I replaced the voltage regulator as well.
  1. Don't fear the oil filter housing gasket
    By Sockethead in forum General -- ZHP Related
    Last Post: 03-25-2014, 04:29 PM
  2. replacing oil filter housing gasket and VCG
    By rikdee in forum Mechanical | Troubleshooting
    Last Post: 05-05-2012, 07:03 AM
  3. Oil Filter Housing Gasket
    By rikdee in forum DIY
    Last Post: 04-04-2012, 10:47 PM
  4. Oil Filter Housing gasket.
    By xtremecro in forum General -- ZHP Related
    Last Post: 09-26-2011, 08:50 AM
  5. Oil Filter Housing Cap
    By anm3itbe in forum Mechanical | Troubleshooting
    Last Post: 09-17-2011, 03:48 PM
