White it is. That’s the one I picked as well.
Installed the Apex studs and the KICS R40 Lug nuts finally. I originally bought all 75mm studs but with a 12.5mm spacer on the rear they didn’t come flush with the studs so I ordered a set of 90mm studs for the rear.
Front
Rear
Also cleaned up the Brembo calipers.
Ran into an issue with two of the front dampers. They apparently didn’t use anti seize when installing them, they are stuck inside the pistons. I let them soak in some PB Blaster for awhile to see if they loosen up.
new lugs look perfect on your ARC-8's Gary! Awesome choice!!
Beauty Gary!
Thanks...
The wheels look great!
The calipers, not so good!
Brembo Rotor
Ya it’s kinda of a bummer. Only 18k on these and found that damper seized inside the piston. UGH!
Oh and some minor mods. I’m running 12mm spacers on the rear. I was getting some tire rubbing on hard dips and speed bumps. It was the typical spot, the rear bumper bolt and bracket. Bye Bye!
Installed this finally. CTEK Mission Control Center.
I got a new QuickJack 5000 SLX for Xmas, used it to install some Turner Monoball RTABS. Also some Morimoto XB LED Fog Lights.
Turner Monoball RTAB's
https://www.turnermotorsport.com/p-5...shings-street/
https://www.theretrofitsource.com/bmw-e46-e39-led-fog-lights-morimoto-xb.html
LED FOGS
LED FOGS & HEADLIGHTS
Quick jack is rad!
