Results 1 to 10 of 10
    Jun 2013
    South FL
    AFE Stage 2 CAI Installation Issue
    I recently picked up a gently used AFE stage 2 intake for my car and tried to install it yesterday but I'm having issues fitting the MAF to the intake. The previous owner said he ran it fine with no issues.
    I looked up the installation guide on the AFE site and it says for our cars, we should be able to put the MAF sensor directly into the intake without the rubber gasket it comes with. The side thats supposed to go into the intake is too big and it won't go in at all. However, the opposite side of MAF fits perfectly but unfortunately, thats the wrong direction.
    Has anyone else had this issue? Is there a way around it?
    Thanks in advance!
    AFE installation guide:
    http://afepower.com/catalog/54-20442/is.pdf
    What happens if you don't use the 45° elbow?
    "No flamesuit required"
    Jun 2013
    South FL
    Haven't tired that. It's safe to mount that way?
    Quote Originally Posted by poke08 View Post
    Safe? What's gonna happen?
    Jun 2013
    South FL
    Yeah never mind. The intake filter is too big for the maf so it won't work
    Ok.
    You don't have the fig E-1 piece installed, correct? Specifically says to not use it with 3.0L engines.
    Jun 2013
    South FL
    I have that piece and thats actually what I used to make it work. Since the MAF wouldn't fit into the elbow, I put the rubber gasket onto the MAF and stuck the other side onto the elbow housing. Then I used two hose clamps to hold it on and now its working well. No CEL lights or funny sounds.
    Thanks Dane!
    Stow, MA
    I just installed and removed mine due to fitment issues, however, you should be able to push the MAF directly into the 45* elbow. Use something to lube both pieces before trying it, but don't go too crazy so that it all doesn't get sucked through the MAF. Mine needed a little bit of trimming on the elbow as well, there was a little bit of build up of casting flash where the tube was rolled.
    -Dave
    2004 330i ZHP sedan- 6 speed swapped, Corsa exhaust
    1997 AW 328i- S52 swapped
    2004 IR 330i ZHP 6MT- aFe Stage 1, Shark Injector, RE Underdrives, Dforce LTWs- SOLD
    1997 Technoviolet M3/2/5- LS1/T56 swapped- SOLD
    Jun 2013
    South FL
    Quote Originally Posted by squashman702 View Post
    The connecter on the MAF didn't fit through the hole on the shield when I took the elbow out. I'll probably take mine out as well since I can't get the screw in since it will bend the intake when it presses against the headlights.
  1. DICE / Audiovox MediaBridge installation & review
    By stephenkirsh in forum Audio | In Car Entertainment (ICE)
    Last Post: 08-26-2014, 06:42 AM
  2. installation in the OC
    By PHZ in forum Audio | In Car Entertainment (ICE)
    Last Post: 09-12-2012, 10:11 AM
  3. Window Regulator Issue....Not the normal zip tie fixable issue
    By 328ioc in forum Mechanical | Troubleshooting
    Last Post: 04-19-2012, 05:59 AM
  4. Suspension Installation Difficulty?
    By Mtnman in forum Maintenance
    Last Post: 06-06-2011, 06:46 PM
