I also just ordered the TRS kit and new bulbs. I'll be doing the install this weekend. Good to know there are others out there taking the plunge!
I was happy with my TRS retrofit kit. Only complaint was the plastic spacers softened with the heat and shrank. TRS sent me new aluminum spacers for free but I haven't installed them yet. The retrofit made my right side AL lights (both before and after accident) look not as good. However, I plan to swap my old ZKW lens to the right side AL light and see if that improves the cutoff.
Have not tried the fixed ZKW bowls from Clemsone but I'm sure they do the job and would be easier to put in than the retrofit.
Did the install on Friday. I can see again!
Good info here. After a few more days I'll move to the "lighting" section so the info is more centralized.
Looking for pics of the beams from inside the car and looking at them from in front.
Here are a couple of shots. There's no question that they're bright enough, and I'm super happy with the Philips 85122 bulbs.
I'm struggling a bit with getting them aimed right. The passenger side only has a couple of degrees of adjustability before it slips and points back up. Worst case I'll have to spend another long evening opening it back up .
That light output is amazing. Great work
I finished my install too along with new Philips bulbs. It is quite the difference and my bowls were not as toasty as some examples I have seen (the drivers side was much worse). My cutoff line is very colorful. I will try and capture in in pictures but no guarantees with a point and shoot canon.
Installation wise, the first headlight took me a while taking things apart and assembling it, the second one was a breeze.
Overall I'm satisfied, with the kit.
