WARNING for anyone that is buying a Siemens/VDO pump or even a pump from the dealer. As of that past month or so many pumps are arriving with the fuel sending arm not fully snapped into the plastic arm on the sending unit.
This MAY???? be an assembly issue that is going un-noticed for QC?
Before you install the pump, inspect the metal rod for the float and make sure it is actually snapped into the plastic sending unit arm that sweeps the level indication, otherwise you will have incorrect fuel level info and you will need to removed the pump again and snap the metal rod into the plastic arm.
No need to return the pump/sending unit assembly, just inspect the arm and make sure it is properly snapped into the sending unit arm before installation.
Anyone else finding this to be a problem, please update this thread, so far there have been just a handful of problem pumps, but I wanted people to be aware of this situaiton.
See this thread for some pictures of what the problem is with the metal float arm not being snapped into the level arm correctly -
http://forum.e46fanatics.com/showthread.php?t=1073902
