Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
    VA/DC
    Completed the retrofit of the bi-xenon EVO-XR lights today from theretrofitsource.com. Kit quality appeared excellent and the user guide on this forum that TomTomTuning made was a great help - http://www.zhpmafia.com/forums/showt...t-doityourself
    Unfortunately I had an issue with my oem shrouds in that the silver was coming off them so I ended up painting them black with SEM trim paint. I'm not sure yet if I like the look. Anyway, off to aim them properly this evening, and will take some pics of light output and some of the lights themselves tomorrow. If anyone is also interested, I will snap a couple of the burnt ZKW's as well, they were pretty bad to say the least.
    Side question, I see people fitting ZKW clear lenses a lot, are the ones I took off the car worth anything?
    Alpinweiss II 1991 E30 318is
    Silbergrau Metallic 2004 E46 330i ZHP
    Sep 2014
    Newnan, Ga
    Car looks great! I need to do the TRS retrofit as well!
    Quote Originally Posted by theothersawyer View Post
    Hardest part is getting the lenses out of the housing, but once you get that out the rest is easy.
    I was a little disappointed to find that the holes that TRS drilled into the frames for mounting are not perfectly level on one of them, so now my passenger side is not a nice straight horizontal cutoff, it slopes down from right to left. I will have to now modify the mounting hole to allow it to rotate around a little so I can get it back to square. Its fine for now though in all honesty, but I can't adjust them to get the maximum amount of center lighting the way they are.
    Valparaiso, IN
    Well hot damn...
    OK, here are a few pictures of the lights after the TRS retrofit. Still can't decide if I like the blacked out shroud look though it does match the black fogs that are on their currently. What I do like about it is that there is still a silver ring around the light as I didn't paint the reflector so it still shows as two headlights which I wanted. I have new lenses on order as mine were in worst shape than I realized.
    In the future I want to add good angel eyes (any recommendations, seems everyone is either Khoalty of Orion V2's), I think that would help even out the look a little (or make it look awful, can't decide). I will probably order a pair of E46-r shrouds in case I want to go back at some point.
Size:  200.9 KBName:  Lights-1.jpg
Size:  121.2 KBName:  Lights-2.jpg
Size:  161.1 KBName:  Lights-3.jpg
    Here are a couple of pics of the burnt out bowls on the original ZKW's..
Size:  68.7 KBName:  Burnt bowl-1.jpg
    Absolutely awful, and it is criminal IMHO that BMW did not recall these lights. The output from these was almost zero..
    I actually think the black looks good. Tossing some Angel Eyes on there wouldn't hurt either. I had Khoalty's and liked them but up close you could see the individual LEDs so if that bothers you I would look for the Orion V4's which have a lot more LEDs to help eliminate that issue.
  1. Replies: 1007
    Last Post: Today, 09:42 AM
  2. Replies: 421
  3. Jon's '03 Alpine White Sedan Project
    By JupiterBMW in forum Projects
    Last Post: 09-02-2014, 03:15 PM
  4. Preston's 2004 zhp project
    By psells_zhp in forum Projects
    Last Post: 03-09-2014, 12:47 PM
  5. Jon's '04 Alpine White Sedan Project
    Last Post: 01-05-2013, 09:38 AM
