Originally Posted by
JeffSaysThings
I run the VMR CSLs (8.5F/9.5R) without any spacers and my wheels are almost perfectly flush with the fender. If you run spacers they'll be poking out. If that's the look you want then go for it. Otherwise you can probably ditch the spacers with those wheels. I personally never cared for poke unless I'm running something pretty wide (>275s).
That being said, you'll probably rub with the spacers so I'd recommend you roll the fenders first (and shave the bumper where it rubs), then try increasing camber.
However, since you're running 245s in the rear, if you don't run the spacers you might not rub with your suspension as it is.
