So the other day I messed up my rear lower control arm pretty bad; now I've gotten it halfway out and am absolutely stuck.
Unfortunately, the control arm is bent in such a way that when I lifted the car (and temporarily lowered it agian) it bent itself even more.
The problem is getting the inner bolt out. The differential is completely in the way, and I am stumpted on how to proceed. I've loosened the front two differential bolts, and also removed the rear differential bolt. I tried prying the differential over to the passenger side of the car while simultaneously lifting it using a floor jack.
I almost got it out, but it's still stubbornly stuck in there.
The next step will be to loosen the subframe a bit while also prying it.
The car is currently in the garage on jack stands.
