Ive been offered a deal on the majority of a 5 speed swap. Since this is a new field for me and online DIYs are a little iffy on parts lists, I was hoping to get someone in here who has done the swap. What else would I need after this list to complete the swap? I know the pedal assembly and clutch master at least.
-5 speed manual transmission
-shifter linkage
-slave cylinder
-flywheel
-clutch (but you might want to buy a new one)
-most of the bolts (id have to look back through been a few months since I swapped)
-transmission support member
-throw out bearing and guibo
-driveshaft (but it is in 2 pieces and dies not have a CV joint, will need to buy one because I had to transfer it to the 6 speed drive shaft cause the one it had was busted)
