As some of you remember this car was for sale in the middle of summer but now I have shifted my focus on purchasing a coupe so now I am looking to sell this sedan. I took a lot from the previous add as it was laid out so well and added a few things here and there
This car is an amazing example of a rust free, southern, well maintained M3. It has some amazing repair history and has never been in an accident.
This car is one of the best driving E36 M3's out there. I can not believe how solid everything is! This is such an amazing example. The only reason I am considering selling is to purchase a e36 M3 coupe so this one has to go because I simply don't have room for 4 cars right now.
I am looking to get $10,000 OBO out of it
UPGRADE LIST
Body:
-New OEM Roundels
-New OEM front windshield cowl trim
-New Bosch wipers
-New OEM hood shocks
-New OEM fuel filler cap
-New Glass DJ Auto Headlights with 55w/5000k HID kit
-New OEM rear window seal
-New OEM door handle gaskets
-New bulbs in taillights
-New OEM M3 front door moldings driver and passenger side
-New OEM M3 trunk badge
-New OEM passenger side 'pork chop'
-Complete tool kit
Interior:
-New OEM anthracite floor mats
-New OEM weighted ZHP shift knob
-New OEM shift boot
-New OEM cabin air filter
-New Alpine CDE-1548T headunit (I have the original one too)
-New BSW Stage 1 speaker upgrade
-3 spoke steering wheel and clock spring (needs to be installed)
-Heated AND Manual front seats (Professionally reupholstered, and in perfect condition)
Suspension/Brakes/Wheel/Tires:
-New Fortune Auto 500 series coilovers
-New Lemforder lower control arms/ball joints
-New OEM FCAB with mounts
-New Mahle sway bar end links
-New OEM power steering lines/clamps (need to be installed)
-New ECS Tuning RTABs with limiters
-New ECS Tuning Rear Shock Mount Reinforcement Plates
-New ECS Tuning Adjustable Rear Lower Control Arms
-New Akebono brake pads (OEM rotors were turned)
-New OEM brake fluid reservoir (screen was missing on the old unit)
-New ECS Tuning steel braided brake lines (with full system flush/fill)
-New APEX ARC-8 wheels 17x9 et30
-New BF Goodrich G Force Sport Comp2 245/40/r17 (mild rear fender roll
to accommodate)
-New ECS Tuning wheel stud kit (needs to be installed)
-New ECS Tuning 5mm spacers (one set)
-OEM LTW X-Brace
-New Sway bar mounts
-ZHP Steering Rack
Engine/Driveline/Transmission:
-30k mile transmission & driveshaft (Sourced from Zionsville Autorsport)
-New OEM clutch, flywheel, throwout bearing, master and slave cylinder (Redline Transmission Fluid)
-5th gear bushings/detents fixed, to prevent 5th gear lean
-New OEM rear main seal, input shaft seal, shift shaft seal, output shaft seal
-New OEM guibo
-New Z3 short shift kit
-New UUC clutch stop
-New OEM air filter
-New OEM oil filler cap
-New OEM cruise control module
-Fresh oil change with Total 20w-50 and OEM oil filter (<1k miles)
-Cooling System Refresh Completed By Previous Owner (Behr Radiator &Aluminum Water Pump)
The Car:
1997 Alpine White M3
161,700
3 Owner, was owned by the original owner in Arizona until April of 2015! (From what I gather, this was a DD for a woman that purchased it off lease)
ZERO RUST!
The Good:
-As you can see by the parts list, nearly every typical e36 problem area has been addressed. There is over $10k in parts and labor this year. All the money spent was to first and foremost make it dead nuts
reliable, and fun to drive. The transmission swap was completed by Reggie's Motorworks in Indiana, the remaining suspension jobs were completed by a local BMW master tech.
-Everything is 100% functional, and the car performs wonderfully. It's a no excuses car that I have zero concerns with driving across the country in tomorrow.
-The car is 100% rust free, as it spent 18 years in Arizona/SoCal. It's garage kept, and driven sparingly.
-The engine is healthy and quiet with excellent compression numbers
The Bad:
-Typical Arizona clear coat peel on the spots noted (hood, roof, rear bumper)
-Headliner is beginning to sag in the rear due to adhesive failure
-Has CEL for bad O2 sensor. PO said that but I haven't confirmed this but I will look into it this week. I was planning on doing headers and an AA track pipe eliminating the O2's
-Interior A pillar covers are warped from it being in the Arizona sun and the headliner needs to be replaced as well.
Here's what the car is:
This car is an excellent example of an OEM+ E36 M3. The paint is not perfect, but it has absolutely zero rust.
On to the pics!
Untitled by Chris, on Flickr
Thank you!
