You're welcome. I don't know the quality of the ECS Tuning ones, but likely someone can chime in.
Welcome. Great example and plan.
Sent from an S6 Edge
Wow so I changed the CCV yesterday 1/26/16 took about half the day including long lunch brake. I started around 930 finished around 330. I spent time cleaning parts and making my engine look nice since I had a lot of stuff removed I made to sure to clean the throttle body and idle valve. One of the ccv hoses had a big tear in it when I pulled it out(pics) and I replaced my intake boot.
After the repair was done I test drove it and noticed the ride was really smooth and felt no vibrations like I was before.
BMW Service quote just to replace ccv $1200 250 for parts and 950 for labor
What I really spent
OEM CCV kit from oembimmerparts $140 shipped
I would say 4-5 hours of work
OEM lower intake boot $15
Removed the Intake, intake boots, DISA valve, idle valve, throttle body, dip stick tube, and all the other little wires and tubes around so I can reach down in there and grab the ccv.
Just getting started
Everything removed that was in my way
New CCV Installed!
New Lower Intake boot installed!
Fixing my lumbar support
Fix Cost $7
time 1 hour
My lumbar was set to max inflation and was stuck!
I should have taken more pictures but I just have before and after pics of the wires.
First took the back panel off I had to cut the 2 christmas tree clips that hold it in place , located the wires to the air pump, took of the lumbar button and the seat control module off. Had to cut the hog ring holding the leather together at the bottom left(I had a bag of hog rings so I was cool) once I had the leather pealed back a bit was able to grab the wires and pull them out and to my surprise all wires cleanly cut.
Crimped the wires, soldered them, heat shrunk them, wrapped them back up and taped them. Put the wires back in, connected everything put the switches back, reattached the leather with a new hog ring. Had to spend 7 bucks on new clips for the back panel and bingo bango bongo my lumbar support works! I can finally relax in my chair with out the lumbar fully inflated
While inspecting my engine I noticed it was the only thing in my engine that was covered in oil so I figured I should replace it. I wasnt getting any codes on my bmw diagnostic program except for my head light and oil sensor. But after installing it I did notice my car isnt as load (use to sound like a vacuum to be honest) it is a lot quieter and runs way smoother in idle and acceleration then what I was previously experiencing
Edit: Only had my car for a month driven about 600 miles
