Page 22 of 30 FirstFirst ... 122021222324 ... LastLast
Results 211 to 220 of 291
  1. #211
    Charleston SC
    seep·age
    ˈsēpij/
    noun
    • the slow escape of a liquid or gas through porous material or small holes.
      • the quantity of liquid or gas that seeps out.
    H&R sport springs,
  2. #212
    Dec 2016
    Greensboro, NC
    Any seepage from those gaskets is just going back to the oil pan...
    Pardon my ignorance, but I can’t tell if you’re saying “seep back to the oil pan” is a good outcome or a bad one...
  3. #213
    Charleston SC
    That part is internal as opposed to an external oil leak which causes oil to seep out of the engine, causing a mess and oil loss. An oil leak inside the engine is just going to return to the oil pan. I doubt those gaskets would leak bad enough to affect the oil pressure needed to activate the VANOS...
    H&R sport springs,
  4. #214
    March 24th
    Tranny Fluid change with Redline D4 ATF
    Installed Apex Arc-8
    I’m planning to take the Zhp out of storage on April 8th, so I started to work on the car slowly. Yesterday I swapped the 135s with the Apex/PSS and changed the transmission fluid. I previously used redline MTL and wasn’t too happy with it after a few thousand miles hopefully the ATF will be better.
    Next on the list is VANOS seals and the “while I’m in there” parts including speak plugs.
  5. #215
    March 24th
    What didn't you like about MTL?
  6. #216
    It was fine for the first 10-15k miles or so but later the gear shifting wasn’t smooth at all, felt like the oil degraded, especially 1-2 shift. But surprisingly as I was draining the oil yesterday, the oil didn’t look too bad, meaning it wasn’t dark and it still had the reddish hue to it. Recently I realized that redline themselves recommends ATF for our cars and some members here recommend it so thought I’d give it a try.
  7. #217
    158378 miles - April 7th 2018
    Changed engine oil and filter.
    Finally took the zhp out of storage after a bit of maintenance. 2 weeks ago I replaced the transmission oil and this past Saturday I replaced the engine oil and filter. I initially wanted to replace the VANOS, VCG and spark plugs while it was in storage but I was quite busy and wasn’t able to get to it. I will be out of the country for 3 weeks starting this Friday so it’l have to wait until end of May most likely. But I’m happy to be driving the zhp again. The car started without any issues. Also I think I prefer the redline ATF over the MTL I had earlier. Shifting gears seems much more smoother now. I drove the car about 200 miles since I took it out and all seems good so far...
  8. #218
    Went past 160k miles this past weekend when I drove to NJ and back on a 1400 mike road trip.
    The VCG leak is quite bad now and is mostly responsible for the 600 Mile half quart top ups. But unfortunately don’t think I have the time till mid June to replace the VCG and VANOS. Car is filthy and is in need of a wash as well.
  9. #219
    163097 miles - June 9th 2018
    Replaced VANOS seals and spark plugs.
    I was so long overdue to replace the vanos seals. The rubber seals were completely brittle and turned to plastic. I also replaced the spark plugs cause they have about 100k miles on them. They looked good with no black deposit on them. I also replaced few other seals which BMWCurves recommended. Overall wasn’t a difficult DIY. Just a lot of nuts and bolts to deal with.
    I noticed the car seems to have a bit more torque at low end which was expected. I’m taking it easy for the 200 miles or so. Since my commute everyday is about 80 miles it shouldn’t take too long. It will be interesting to see how much difference there is once I start driving normally.
  10. #220
    Dec 2016
    Greensboro, NC
    Nice, glad you got it squared away.
  1. Replies: 1009
    Last Post: 04-19-2024, 05:11 AM
  2. Replies: 594
  3. Replies: 769
  4. FinanceGuy's Maintenance/Project thread -- 08 E70
  5. Replies: 12
