Results 1 to 10 of 16
    Feb 2016
    Hoboken, NJ
    NCS Expert / PA Soft
    So I bought in INPA dcan cable over Amazon thinking I could use it on PA Soft. Wrong. After a 7/8 pin mod, everything in the Demo version of the PA soft would work but full version was waiting for the BMW adaptor to connect (I don't have it). So I gave up and went the INPA , EDIBIAS , NCS Expert route.
    Maybe I can edit a driver information file to get PA soft into thinking the BMW Adaptor is there by changing the name ... Not sure.
    Now is there anything that PA soft can do that I can't do with NCS Expert? Even though PA soft is easy to use , I have no problem using NCS expert.
    Sep 2011
    San Francisco, CA
    Nope. PA Soft is completely different from the BMW KCAN/DCAN cable. I have both adapters because the FTDI drivers don't play nice with one another.
    Feb 2016
    Hoboken, NJ
    Second part of the question is: is there anything I can't do with NCS expert that I can do with PA soft?
    Feb 2016
    Hoboken, NJ
    My main goal was to recode the instrument cluster temperature gauge. I saw the hex dump in the screenshot of PA soft on what lines to edit. Would I need to read the cluster Ecu in NCS and find the same lines of code in nettodat? They I don't think they show in fsw_psw
    Aug 2011
    Las Vegas, NV
    Quote Originally Posted by burns View Post
    Calling BP!
    Feb 2016
    Hoboken, NJ
    Currently in the middle of the struggle of getting GT1 v39 working on my MacBook Pro via parallels via VMware . Some serious forum surfing this weekend. So far at the roadblock of copying shadow fdd to the SCO files...more troubleshooting to come.
    But the question about the cluster is still on my mind.
    Jul 2014
    European Auto Source
    NCS is much more in depth than PA. You can change every little detail, but you can also seriously screw up your modules. Im looking for progman at the moment to full flash a new VO after manual swap
    Modification Thread
    Original Car: Silver Grey on Grey, A/T (1 of 186)
    As it sits: Silver Grey on Black, M/T (1 of 51)
    European Auto Source Tech
    Instagram: @CarbonZHP
    Feb 2016
    Hoboken, NJ
    Question still is : can I edit the same line of code as stated in one PA soft DIY article in NCS Expert?
    Jul 2014
    I have to use both pretty often
    Sent from my XT1585 using Tapatalk
    Modification Thread
    Sep 2011
    San Francisco, CA
    No. Coolant Temperature and Speedometer Calibration correction are not available via NCSexpert.
    Also, you should look into ISTA/D and ISTA/P instead of GT1. It's a hell lot of easier to install and will be capability for newer BMWs as well.
    MHHAuto is one place that you can look.
  1. Replies: 10
    Last Post: 06-01-2015, 08:18 AM
  2. soft brake pedal.
    By BRGcoopahS in forum Mechanical | Troubleshooting
    Last Post: 10-10-2012, 04:32 PM
  3. Hard Wax v. Soft Wax
    By llll1l1ll in forum Detailing
    Last Post: 09-23-2011, 10:15 AM
  4. How to use NCS Expert?
    By az3579 in forum DIY
    Last Post: 05-26-2011, 10:33 PM
