Page 6 of 8 FirstFirst ... 45678 LastLast
Results 51 to 60 of 77
Thread: BMW E46 ZHP DIY and Preventative maintenance doityourself
  1. #51
    Lebanon, OH
    48. ECSTuning Brake bleed procedure and information
    http://www.ecstuning.com/BMW-E46-330...1/Video247-SD/
    "Flame suit NOT REQUIRED!!!"
  2. #52
    Aug 2011
    Las Vegas, NV
    Dane can you add this link into #39 for the Automatic Transmission. This is a really good DIY for doing a fluid change with several links. Also for those that can't measure the operating temp during the fill procedure my trans fluid temp was 95 degrees after 10 minutes of idling.
    http://forum.e46fanatics.com/showthread.php?t=438667
    BAVSOUND Stage 1 - UltraGauge - Valentine One - Orion V4's - ARC-8's
  3. #53
    Lebanon, OH
    Thanks Wolfy.
  4. #54
    Fayetteville, NC
    Man that oil change video with the oil filter coming out in pieces
    Perhaps one should add that WIX oil filters are not OE/OEM and one should go with Mahle or Mann...easy to find, too.
    I find this one (although using a pump and not a pan-drop OC) a much better video and very well shown/explained:
    http://www.youtube.com/watch?feature...&v=v2v8yAjx5iw
  5. #55
    Lebanon, OH
    OK......will view tomorrow Washy. Thanks for the input.
  6. #56
    32.8 N, 117.3 W
    bumping for newer members, this thread has a lot of info...
  7. #57
    Lebanon, OH
    Quote Originally Posted by Washburn View Post
    Updated. Thanks Washy.
  8. #58
    Aug 2011
    Las Vegas, NV
    UnBump! oops...
  9. #59
    Why is this being bumped, and not just a sticky?
  10. #60
    Salt Lake City, UT
    I love this thread. Helped me save some serious coinage.
  1. doityourself
    By danewilson77 in forum Minutiae
    Last Post: 10-15-2016, 01:38 PM
  2. OBC 19.7.00 - Watcha' go? doityourself
    By Oli77 in forum Maintenance
    Last Post: 02-10-2016, 08:57 AM
  3. Vanos as preventative maint? Deal at local indie....
    By Washburn in forum Maintenance
    Last Post: 05-21-2013, 01:33 PM
  4. BMW E46 ZHP DIY and Preventative maintenance doityourself
    Last Post: 10-06-2011, 01:46 PM
  5. Replies: 17
    Last Post: 01-05-2011, 11:34 AM
