Nope, not at all. Usually it's over tightened so bear that in mind when you replace it. It has an O-ring so it doesn't need to be super tight.
Have we discussed the brass replacement option yet?
S7 Edge, out
Negative...
Oooh! I had a coolant leak that looked exactly like yours. Crusty around the top of the expansion tank, and lots of drips all over the place. I replaced everything in the cooling system except my upper radiator hose. Guess what? The plastic fitting on my upper rad hose was a piece of crap, and was letting coolant slowly drip out over the top of the expansion tank.
I remember worrying about it daily, every time I drove it. Constantly turning my center display to show temperature, etc. while I was trying to eliminate the issue. While it would be SWEET if your problem was just the bleeder screw, I would assume that with that much around the ET, it's gonna be either the tank or the upper radiator hose.
2004 ZHP Vert - Titanium Silver 6MT
BMW CCA Rocky Mountain Chapter #504522
ZHP Replacement: 2012 E93 M3 * Daily Driver: 2007 Hummer H3 Adventure * Wife-mobile: 2016 VW Touareg Exec
So, follow up... It's fixed. I think it was indeed the bleeder screw.
I took it out and cleaned it up, and couldn't see anything wrong with it. I screwed it back in and it broke off in the receptacle. Arggghhhh...
So I used a technique I saw on E46F, heated a regular screwdriver with flame, and melted a slot to screw it out...
Picked up a new one at the dealer, put it in, bled the system, and I think I'm all squared away.
Cars and coffee in the morning!
Thanks, guys!!!
SC
Btw, after comparing new and old, I think it was a combination of a deformed (flat) o-ring, and then the screw itself was failing structurally and developed a pinhole from the top of the threads to the big recess in the center.
SC
