Results 1 to 8 of 8
    Quakertown, PA
    Anyone have a good power steering fluid flush DIY?
    Noticed my power steering reservoir had a film of oil all over it like it's been leaking and sure enough the cap gasket was missing... Then I noticed the oil in there was very dark and slightly burnt smokey smelling and I figured maybe it hasn't ever been changed...Car has 47,000 miles on it.
    So me thinks I will be adding to the list of fixes, but I have never done it before.
    So any help for a novice would be great!
    2002 330XI Saloon
    2005 ZHP
    2013 XC90 R-Design
    Dec 2010
    Santa Cruz County, CA
    More than you asked for, but this is one approach...
    http://www.bimmerfest.com/forums/sho...ring+flush+diy
    Personally, I used my mity-vac to evacuate the reservoir, refill with fresh ATF, start the car and move the wheel from full lock to full lock to circulate the fresh fluid (many times), rinse and repeat until I used up a full liter of fresh fluid.
    You may want to pull the belly pan off and have a look see at your lines. On my car, the high pressure line at the rack, yes - the really expensive one, is seeping enough fluid to collect in that belly pan, but not drip onto the ground. At my last track inspection the mechanic said it was normal and acceptable in it's current condition. He said when you hear air sucking sounds, that's when it's time to replace them with official BMW parts.
    Jeff
    Golden Gate Chapter BMW CCA - Autocross - Join Us!
    "You drive like old people $#@%... slow and sloppy!" - George Carlin
    I did the Nathan Carter TB flush.
    TB = Turkey Baster.
    Buy one qt of M1 ATF, suck as much outta the resevoir, and fill with fresh ATF. Then driver 300 miles, and repeat the process 3 times. At the end....you end up with just about fresh fluid in your system.
    Droid! Srs Legitness!
    Quakertown, PA
    Thanks Jeff and Dane for the help. It doesn't appear I have any leaks so I will forego the complete swap out and just go purchase a big fat turkey baster some ATF and a damn gasket for the cap.
    2002 330XI Saloon
    2005 ZHP
    2013 XC90 R-Design
    I got my TB at Advance Auto Parts. It is actually a Battery Electrolyte sucker thing (BEST). It made me feel better buying it at an auto store. Works like a champ. Three sux......and the reservoir is empty. Mine is red. It is good.
    Quakertown, PA
    haha was just there and bought the same one I think, it's red. Like Imola Red. I think it matches your car?
    2002 330XI Saloon
    2005 ZHP
    2013 XC90 R-Design
    Imola red FTW.
    spencers Guest
    I followed this one this weekend
    http://www.linquist.net/motorsports/bmw/maf
  1. Replies: 27
    Last Post: 06-20-2013, 06:38 PM
  2. OMG...So flush!!
    By Rovert in forum Wheels
    Last Post: 09-01-2011, 09:42 AM
  3. What kind of Fluid?
    By L0veZHP in forum Maintenance
    Last Post: 05-19-2011, 10:14 PM
  4. SMG Hydraulic Fluid (Pentosin CHF 11s)
    By mikeyb74 in forum Mechanical | Troubleshooting
    Last Post: 03-22-2011, 09:31 AM
