yesterday was halloween, or Martin Luther Day around our house, where we watch a family movie and eat way too much junk/candy together. so i didn't get much work done at all - only had about 30min - but i got the trans separated from the engine, and decided to take a little video to demonstrate DMF wear.
so here ya go. this is the initial inspection - i'll do another today after i remove the PP/clutch/DMF and get it on the engine stand.
Yikes! I wonder what mine looks like.... I haven't been easy on my car in the 100k+ miles I've owned it...
ha! me either, i've put 85K KMs on it since i bought it (roughly ~53K miles).
i got the PP and clutch removed yesterday, along with assembling my new engine stand and realizing that i needed some long and strong M12x1.75 bolts to fasten the engine to the stand - which means a 35min drive each way to pick some up either today or tomorrow - bollocks.
interesting notes: the bolts that secure the PP to the flywheel are REALLY soft - one rounded out without my effort, and i had to cut it off with my grinder. oh well, it's all going in the trash anyway. clutch had decent meat left - for 3 owners and 261K KMs, that's good. happy with that. the flywheel was as expected... no real hot spots (i'm not a clutch-dumper), but the axial play was surprising... i've never examined a DMF up close before. here's a brief video after the clutch and PP were removed...
i pulled a few more little bits off the ZHP last night, and today the doors, gloss black shadowline trim, master cylinder and brake booster, and trunk are getting pulled. the shell is scheduled to be picked up tomorrow afternoon! progress!
yeah, considering it shouldn't have any. i'll post another video, or pic, with the new SMF on there. also going to clean the engine (not ridiculously clean, i don't see a point... but just get most of the grime off), fully remove the old CCV and install the G.A.S. CCV finally, replace the oil pan gasket, clean the IACV, replace the A/C belt tensioner pulley, and rear main seal (mine is weeping slightly... which could be from too much vacuum introduced to the crankcase from my catch can setup - as gary @ G.A.S. theorized). i might as well replace the OFHG (which is only 2-3 years old) with the viton one from bavauto. all of that stuff is WAY easier on an engine stand (except the RMS) than in the car, so.... yep.
still deciding whether i will end up putting the ZHP rack into the Touring or not... i like the ZHP rack in the twisties, but the stock Touring rack is so much calmer on straight roads, like highways. hmmm.
also, ordered a new set of TRW ZHP front control arms today. i used one on a friend's car last spring and was impressed with the quality - especially for only $111USD/each at FCP!
done.
er....whoops.
Absolutely no question. ZHP rack all day long.
Not really sure what you mean by calmer. The ZHP rack still feels perfectly relaxed on the highway. The twitchiness is usually caused by tires.
my alignment specs likely have more to do with it than the tires, because my black Touring had a ZHP rack and it was twitchy also. you have to remember that i am bouncing between cars, so i notice the changes... if i was driving the ZHP and nothing else it wouldn't seem weird to me. on the ZHP, i was running -1.5º camber up front, and -0.8º in the rear. once the Touring is complete, i will likely run -1.0º up front and -1.2º in the back. it was a little too tail happy for me before... especially with my driving style. those camber specs should be a happy medium between stock and what i ran before.
ZHP shell went bye-bye today. picking up 100mm M12x1.75 class 12.9 bolts this afternoon so i can get the M54B30 onto the engine stand. going to get get as much prep work done ahead of time before taking the Touring off the road - even though i have a lot of work ahead of me once the Touring swap is underway as i have the install the VinceBar and VinceSkinz - and that is a lot of cutting, drilling, test fitting, epoxying, etc - also, i've never done it before, so i will be going quite slowly.
