Results 1 to 7 of 7
    Coolant light on briefly, however coolant level appears fine.
    Getting a bit colder so this all may actually have coincided with having the heat on for the first time in many months. The coolant light came on briefly (~60 seconds) and then went away a few days ago. Same situation today.
    I checked the level after the car had cooled off and the floating gauge pops right to the top so doesn't appear low. I'm aware there is a bleed screw of sorts right by the coolant cap, so do I need to open that up to get a true read of coolant level?
    Thanks
    Whatever you do... No over filling.
    Sent by the Pixel XL
    I had the same symptoms last year. My Indy replaced the expansion tank and that was the fix. He said there's a sensor in the unit, and it failed.
    I'm pretty sure the sensor is separate from the tank itself. You should be able to replace just the sensor, but you'll have to drain your coolant since it's in the bottom of the tank.
    Jun 2014
    Toronto, ON
    Can confirm, the sensor just plugs into the bottom of the expansion tank and it is a separate part. Part# 17137553919.
    anandoc
    Last time the cooling system was replaced? Might be time to do a basic overhaul of it before winter.
    Feb 2016
    Dallas, TX
    Mine does this since the temperature has dropped. My entire cooling system was replaced in February, so I was skeptical that anything was amiss since I haven't seen any spots or puddles under my car.
    I suspect that my system wasn't filled or bled properly according to the info here:
    http://www.bimmerforums.com/forum/sh...-light-fix-E46
    Being that it's just a light and doesn't stay on for very long, I've let it be until I have enough time to dedicate to fixing it.
    5/2003 Silbergrau Metallic ZHP
    - Sedan :: 6MT :: Style 68 -
    h&r | drvanos | koni | active autowerke | vibrant | akg | turner
  1. Coolant level warning light dx
    By Asiah119 in forum Mechanical | Troubleshooting
    Last Post: 11-14-2014, 10:00 AM
  2. coolant level too high?
    By Jlastor in forum Mechanical | Troubleshooting
    Last Post: 06-01-2013, 12:32 PM
  3. Coolant light came on
    Last Post: 10-14-2012, 06:32 PM
  4. Coolant light came on...
    By CERF04ZHP in forum General -- ZHP Related
    Last Post: 03-29-2012, 07:29 PM
  5. My low coolant light came on today
    By 3ZHPGUY in forum General -- ZHP Related
    Last Post: 12-20-2010, 06:49 PM
