Originally Posted by
dpark
This keeps getting better and better. The plastic covers for the headlight washers are SUPER flimsy. Turns out both of mine were already broken on the inside, the two loops of plastic that connect onto the headlight nozzle. Surprised neither of them fell off by themselves. I superglued them back together for now and have ordered a new headlight washer nozzle for the right side, and also a new headlight washer pump and filter sleeve to see if this solves the problems of the leak and the zero water pressure on the left side. I think the leak is with the broken headlight washer nozzle. What a pain in the butt...
As for the plasticy headlight washer covers, where do you go to get new ones painted? on FCP Euro, they come primered. Do you just buy touch up paint and paint them? I can't see a body shop going through the trouble of painting things so small...
In response to your painting issue I'll include the information for ordering the correct matching paint for your car. Yes, you are correct in stating most body repair shops won't wish to deal with such a low order/job. I have gone this route when repairing small areas on my MINI and BMW. The match was PERFECT and indeed sped things along with little hassle.
That said, I had issues with my washer system.. Maining due to my removal of the lamps to install the angle eyes. They really are not that much of an issue once one figures out the sequence. The breakage I can image comes from improper removal of the finish plate (with the the two hoops on the back and it's separation from the nozzle. Upon study it's a really simple press out system (with a slight "twist"). The trick is to use a pick tool. Pull out the assembly (you'll meet resistance (or actually more accurately a dampened resistance) due to the system is under pressure. Well, not if you if have a leak or the system is empty. Anyway, grab the whole thing and pull with your grasp near where the nozzle inserts into the rest of the system. Of course once it pulls out fluid will drain out. Either drain the system beforehand (if it's not empty already) or let the remainder drain into a receptacle.
Once replacing the damaged nozzle with new (or just reassembling with the intact old one due to some other factor) and snapping onto the cover via the two loops just insert the entire sub assembly into the cavity aligning the nozzle stem into the retracted receptacle open ended tube. Then press home. You'll feel it snap in place.
I've done this a few times with the same part and no leakage issues. Neither with the replacement NOR the old 9 year old one.
Also remember the parts are handed (left - right)
Yes, I know I could omit them but I'm anal about keeping things functioning as they were intended. And with a relatively simple system albeit ("fiddly" ) I don't mind keeping the OE system in place.
The paint source:
our Order was placed with AutomotiveTouchup.com. Thank you very much for your order!
We typically take 5-7 business days to process, formulate, manufacture, and ship out your order during peak times. This is because your paint is CUSTOM-MIXED for you and your vehicle. Selecting a faster shipping method does not guarantee a quicker manufacturing process.
If you need to talk to someone in the meantime contact us Toll Free 1-888-710-5192.
ITEMS ORDERED
Item No.: AER-BC
Description: 12 oz Aerosol Spray Paint, 2005 BMW 3-Series: Sparklng Graphte Metallic A22
Quantity: 1
Item Price: $19.95
Item Total: $19.95
Item No.: AER-CC
Description: 12 oz Aerosol High Gloss Clear Coat
Quantity: 1
Item Price: $7.95
Item Total: $7.95
We look forward to serving you again in the future,
AutomotiveTouchup.com Sales Team
A Microfinish LLC Company
Reason: spelling
2014 MINI Paceman S ALL4
2005 BMW 330ci ZHP
2005 Lotus Elise
2003 MINI Copper S
2002 Porsche 996 - 911 C2
1988 Porsche 928S4
1978 Jaguar XJ6L
1969 Triumph TR6
1965 Lotus Elan S2
