Page 1 of 3 123 LastLast
Results 1 to 10 of 30
    Feb 2016
    Portland, Maine, USA area
    Battery failed: need help
    I have done a (admittedly quick) search on this topic and am starting anew, largely because we have a blizzard just ending and the pressure's on.
    My battery just failed beyond normal-jumpable status after a year of as-new ownership. It supposedly was installed exactly a year ago when I bought the car at a 3rd-party dealer.
    AAA just left: they got the car started where my wife's jump and my minibattery wouldn't. They show the battery as being about 18 months old. He said I'd been given a low quality battery from an off-brand. The guy, who seemed smart and competent, was totally spooked about replacing my battery: talked about blowing a main fuse twice out of the last 3 BMW's he'd been called on. Also mentioned the car has to be synced to the battery (possible with PASoft, presumably?) I'm not a wrencher but could mechanically swap a battery and do work in PASoft. I hate to pay the local indie, and to wait for him to get around to me.
    Experts: what path would you recommend at this juncture? Many thanks in advance.
    Other tweaks: see my profile
    Salt Lake City, UT
    Coding batteries to their cars is newer than the E46. Don't worry about that. I think that started on the E90.
    Go to Autozone and get your battery tested. If it's bad, check for a warranty. If there is no warranty, I think you're SOL. Get another battery, and a good one.
    In the market for an E90 M3
    Feb 2016
    Gotcha, and much appreciated. One point I forgot to ask about: why the battery failed so precipitously once cold weather hit? I called local shops and was told that having a good-quality (Aukey CC-S1) cig-lighter in place but not connected to phones, etc could be putting a detrimental load on the battery.
    Really? This was not the case with any of the other cars in our household over the last decade or so.
    You could have a parasitic drain on the battery. Things such as the FSR (final stage resistor I believe) are known to go bad on these and cause that. And as said, replacing it is no big deal at all. Get a good one (there are some recommendations in a thread somewhere on here), and just replace it yourself. No coding, no muss, no fuss. Just unhook the old, put in the new.
    Feb 2016
    More just now: AutoZone is also leery of replacing the battery: the guy quoted me (on the phone) about a note saying the system had to be reset when the battery is changed. AutoZone is the best-quality store of its kind in my area so I don't think I have other options.
    Change the battery and roll? No reset or other software issues? Just checking here before I brick the vehicle at an AutoZone.
    ON EDIT: JR's post came in across mine. I am headed to the shop.
    THanks all.
    Just change the battery yourself , no issues will occur.
    They think it's a 2006 E90, not an '06 E46. Just tell them it's a 2005, it will avoid issues, and the cars are the same. I never list my car as an '06 when looking for parts. You can imagine 2 different production models using the same year causes confusion.
    I went to AutoZone to replace my battery last year. They wouldn't do the replacement themselves because it was in the trunk and not in the engine bay (their installation only extends to what they consider "standard battery locations"). Bring tools with you or do it at home and return your old battery to get your core deposit back.
    You can blame me, and my "jokes" about stuffing people in my trunk, for that policy.
    This, when I order parts I enter 2004 instead of 2003...it's the part.
  1. So erm.... My glovebox failed...
    By BRGcoopahS in forum Mechanical | Troubleshooting
    Last Post: 05-01-2013, 04:36 PM
  2. Failed/failing alternator?
    By telijah in forum Mechanical | Troubleshooting
    Last Post: 02-08-2013, 11:38 AM
  3. I failed
    By M3TA5IN in forum Reunion Gallery
    Last Post: 05-23-2012, 06:25 PM
  4. I think my thermostat failed, help with conformation?
    By 328ioc in forum Mechanical | Troubleshooting
    Last Post: 03-16-2012, 12:07 PM
  5. So I failed my MD inspection...
    By Newjack in forum Maintenance
    Last Post: 06-20-2011, 04:25 PM
