Page 18 of 19 FirstFirst ... 816171819 LastLast
Results 171 to 180 of 186
  1. #171
    Wow, I'm switching to Brotella too.
    I was burning about a quart every 5-600 miles at first. Then I did the 02Pilot mod which bumped it up to about 1200 or so. When I do my next oil change after I get the car back, I'll install the CCV too and see what happens.
    -Corey
    2003 Blue ZHP Sedan @ 210k
  2. #172
    Quote Originally Posted by Smolck View Post
    It's the detergent packs they use, cleans the oil control ring. Add a can of lubro moly engine flush and let the car idle for 15 min before your next oil change, prepare to be amazed.
    Which one in particular are you talking about? When googling that product, it seems there is a Lubro Moly branded product and a Liqui Moly product, as well as some variations within those brands. Exhibit A and B:
    Lubro Moly Pro-Line Engine Flush: https://www.amazon.com/Lubro-Moly-Pr.../dp/B003U53J0A
    Liqui Moly Pro-Line Engine Flush: https://www.amazon.com/Liqui-Moly-20...EBKR30ERS61E8J
  3. #173
    I used the first one. My local NAPA carries it.
  4. #174
    Jan 2016
    Chicago area
    They are probably the same product. Part number is the same.
  5. #175
    Nov 2017
    Seattle
    I am running rotella in mine right now, per the recommendation of someone here or on e46fanatics. I didn't want to go for the full on flush, so I decided to try Rotella, since it has better detergents. My cold start rattle has minimized significantly, although I do not know if it is from the Rotella, or simply from new oil + new CCV system. I am probably going to drive it for a total of a couple thousand miles, then drain and refill with Mobil 1.
  6. #176
    Dec 2017
    Lake Wylie, NC
    Smolck, I used the engine flush on my first oil change since getting the ZHP. I assumed the engine was gunked up. I need to replace the OFHG soon. If it wasn't leaking before the flush, it sure is now. The valve cover gasket didn't spring any leaks. I mainly just want to see how the top side looks and how well the flush did at removing deposits. I'm running Castrol 0W40 Euro right now, but will give the T6 a try next, and then replace the valve cover gasket and check out the top side. I can't stand gunky engines.
    Salty
    Bone stock at the moment
  7. #177
    Nov 2017
    Seattle
    Quote Originally Posted by SaltyNC View Post
    Do you mean that reddish brown sludge that accumulates on the underside of the valve cover? I just sprayed it with degreaser and hosed it off when i did my VCG. Then I had to meticulously get at every damn crevice on that damn honey comb underside with a paper towel.
  8. #178
    Charleston SC
    Quote Originally Posted by papa_g View Post
    haha! that sounds familiar
    H&R sport springs,
  9. #179
    Dec 2017
    Lake Wylie, NC
    Yeah, I don't like to see varnish, sludge, etc. around the valves, cams, VANOS, valve cover, etc. I'm hoping the engine flush (and maybe a few more and possibly some T6 high detergent oil) will eventually get rid of all that. I checked my oil last night, and it's still amber since the flush, so that's a good sign that at least it got rid of some of the crud on this 155K engine.
    Salty
  10. #180
    Jan 2016
    Chicago area
    I received my kit last week. I must've been one of the last ones to sign up. Now...to find the time to install
  1. Trunk Release Switch no longer works
    By Mr Paul in forum Mechanical | Troubleshooting
    Last Post: 09-13-2020, 07:20 PM
  2. Too early for VANOS?
    By Washburn in forum Maintenance
    Last Post: 04-20-2015, 06:30 AM
  3. Starting her early!!
    By SureShot434 in forum General -- ZHP Related
    Last Post: 12-27-2013, 09:29 AM
  4. Early Morning and My ZHP
    By echo46 in forum General -- ZHP Related
    Last Post: 01-18-2013, 11:49 PM
  5. Replies: 33
    Last Post: 09-21-2011, 04:41 AM
