Page 3 of 19 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 186
  1. #21
    May 2016
    Pekin, Illinois
    Do you have details of this heating trace that you designed?
  2. #22
    Quote Originally Posted by roadbiker_2 View Post
    So, is this a good solution or would a catch can be a better choice in the long run?
    if this combats freezing adequately and puts the required vacuum on the crankcase, then yes, it's a perfect long-term solution. i would buy one - the packaging is fantastic on many levels.
    if it doesn't combat freezing, i might still buy one and apply my heating solution.
    yep, my protoype setup is here:
    http://www.zhpmafia.com/forums/showt...sible-solution
  3. #23
    May 2016
    Pekin, Illinois
    Thanks, I will check it out
  4. #24
    very interesting design. i've been waiting for this thing for a while, too! i like how it interfaces directly with the outlet on the valve cover and also the inlet on the intake manifold.
    also, it is a pretty cool packaging idea to mount it on top of the oil filter housing - that makes a lot of sense. i'm curious why they're draining back to the pan though, and not right into the oil filter housing?
    anyway, here is a link to the cool nerdy stuff (nate, i'm talking to you here ). all of my questions....save one... are answered here:
    http://www.germanautosolutions.com/b..._info_page.php
    this thing looks killer. i will most likely buy one. the one thing that does concern me - and this is my major beef with the CCV system - is freezing. i'm concerned that the condensate could still freeze. i will be contacting them about this.
    Yep, I went through every detail on that page and was going to send it to you, but figured it would be better to create a thread and make our technical ramblings on this public.
    The drain all the way back to the oil pan is confusing to me too. Until you hear back from them, we'll have to assume that they tried draining to the filter area and found that adding a port to the filter housing created issues with the flow of oil through the filter.
  5. #25
    Apr 2012
    Hereford, AZ
    Quote Originally Posted by stephenkirsh View Post
    I've heard it won't pass visual inspection.
    So... not sure this thing will. But who knows?
    So, who wants to be the first guinea pig?!
    Visual inspection? What's that? Here in Arizona, your car passes "visual inspection" by pulling into the testing booth.
    I'm intrigued by this piece, I already have GAS's Disa Gold, perhaps I'll add one of these as well. Zero issue with passing smog here.
    '21 M2 Competition
    '08 Z4 M Coupé
    '19 Golf R
  6. #26
    In CA they open your hood and check things out. I'm not sure why it wouldn't pass as how the heck would they know what that is?
  7. #27
    i just spent a good 30 minutes on the phone with gary @ G.A.S.....
    long story short - he is an awesome dude and is 100% committed to this system. he really has spent 3 years R&Ding several iterations of this system on his own personal car (E39), and after talking with him i am convinced it will be the right solution for me too. lots more details to come! this really is a no-compromise system and will solve all issues present with the factory CCV system.
    also, apparently with a PCV system it can suck air in THROUGH the rear main seal, which as you can imagine couldn't be a good thing, especially in a dusty environment. his system will draw more vacuum that a stock CCV (about 1.5x), but not as much as what i'm running now. also, it filters the oil out from the air so well that effectively zero oil is making its way back to the intake - i mean, even on my system i am getting oil in the intake.
    the drain-back works well and due to the aforementioned filtering, no condensate is going back to the pan. now THAT is good news.
  8. #28
    Just caught up on this... once GAS has this for sale I may just pull the trigger on this....
  9. #29
    May 2016
    Pekin, Illinois
    Nice, thanks for making the call. I was very impressed with the DISA kit they made as well.
  10. #30
    Nice! Thanks for doing the leg work. This system obviously needed to be approved by Canada's catch can guru before ordering.
  1. Trunk Release Switch no longer works
    By Mr Paul in forum Mechanical | Troubleshooting
    Last Post: 09-13-2020, 07:20 PM
  2. Too early for VANOS?
    By Washburn in forum Maintenance
    Last Post: 04-20-2015, 06:30 AM
  3. Starting her early!!
    By SureShot434 in forum General -- ZHP Related
    Last Post: 12-27-2013, 09:29 AM
  4. Early Morning and My ZHP
    By echo46 in forum General -- ZHP Related
    Last Post: 01-18-2013, 11:49 PM
  5. Replies: 33
    Last Post: 09-21-2011, 04:41 AM
