Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 57
  1. #21
    Jan 2017
    Huntersville, NC
    So if I create a new parameter with NCS Dummy called "funfmal" and set the data to "5" and update the DATEN file, when I go to NCS Expert, do I now set CYCL_TI_BLK to 'funfmal' (as opposed to einmal and dreimal) in order to achieve the 5 blinks?
    Precisely!
    BTW, when you make a change in NCS Dummy to the Daten file, it automatically creates a backup in the Daten files directory. It even warns you as you save the modified Daten file that a backup will be created.
  2. #22
    Jun 2014
    Toronto, ON
    Quote Originally Posted by Overboost View Post
    Precisely!
    Thank you so much!! I will attempt this over the weekend and report back.
    anandoc
  3. #23
    Sep 2011
    San Francisco, CA
    Quote Originally Posted by anandoc View Post
    FWIW, you can name it whatever you want. I wanted my parameters to be named like the default values of one time, 3 times. So I have 4 times, 5 times and 6 times in german.
  4. #24
    Jun 2014
    Toronto, ON
    Quote Originally Posted by derbo View Post
    Yup, I too want the naming to be consistent so I will go with funfmal (5 times).
    anandoc
  5. #25
    Feb 2016
    Portland, Maine, USA area
    Looking at all of this from the outside, it seems like a real lot to go through. I wish I could activate this on my 2006, which will probably prove to have a higher software version, but I only have PASoft. The whole NCS Expert/Dummy dance: man... I'm gonna use my left hand.
    Other tweaks: see my profile
  6. #26
    Sep 2011
    San Francisco, CA
    Quote Originally Posted by Dual View Post
    It's not a lot of work. After you get going with NCSexpert you can do alot other things too.
  7. #27
    Jan 2017
    Huntersville, NC
    NCS Expert is just one of those tools every BMW owner should have just as you found with PA Soft. There are many of us here that are willing to lend you a hand.
  8. #28
    Sep 2011
    San Francisco, CA
    BMW coding tool makes a nice GUI as well
  9. #29
    Jan 2017
    Huntersville, NC
    BMW Coding Tool made updating/adding my Daten files for WinKFP a snap. Absolutely a great tool.
  10. #30
    Jun 2014
    Toronto, ON
    Thanks for all your help here guys. I just coded 5 blinks into my car
    anandoc
  1. LCM Software Update to 4.5 - Enable Triple Flash (and more)! -- $70 + core
    By terraphantm in forum ZHP-Related Parts & Accessories (no vehicle sales)
    Last Post: 12-27-2017, 08:00 PM
  2. NCS Expert / PA Soft
    By burns in forum BMW Coding
    Last Post: 11-07-2016, 12:02 PM
  3. Replies: 10
    Last Post: 06-01-2015, 08:18 AM
  4. How to use NCS Expert?
    By az3579 in forum DIY
    Last Post: 05-26-2011, 10:33 PM
