Results 1 to 10 of 10
    Jul 2014
    Eastampton, NJ
    Replaced my Oil filter housing gasket and now,
    I got tired of smelling oil while driving my car so I changed the Oil Filter Housing gasket this morning. That was definitely a source of leakage. Now with everything buttoned back up my car has a terrible idle. I thought that maybe because I had the battery disconnected for a while that the electronics need to find itself again. I put about 10 miles on it today and its a little better but not good and before I started this project it was fine. I seems to run normally other than that and pulls fine at low rpms but the idle stinks. No good deed goes unpunished. I was wondering if anyone else had experienced this. Possibly I just have to give it a little more time.
    Dec 2010
    Fairfax Station, VA
    After disconnecting the battery, give it 40-50 miles to relearn itself. It that doesn't fix it, perhaps you dislodged an air intake boot or the little F connector vacuum lines when you were messing around with the OFH stand gasket.
    Bruce
    21 GMC Sierra - mine
    16 X5 M-Sport - wife
    11 M3 - 1st son
    04 Tundra - 2nd son
    17 X1 M-Sport - daughter
    Former (mo/yr sold):
    15 335xi M-Sport (8/18)
    11 335is (8/17)
    11 X5 AW/blk (11/15)
    04 330xi blk/gray (7/15)
    06 ZHP SGM/blk (6/15)
    08 335xi blue/blk (4/15)
    04 ZHPci MB/blk (2/14)
    04 ZHPcic IR/Alc (10/13)
    01 540iT anthra/blk (7/13)
    04 ZHPci TIAG/blk (9/12)
    03 540i M-Sport (9/12)
    01 325ci (3/12)
    02 325iT 5MT (10/11)
    05 ZHPci (7/11)
    03 330cic (2/11)
    00 323ci (10/10)
    Jul 2014
    Eastampton, NJ
    Thanks maybe I'm being a little too impatient. I did check for vacuum and intake leaks. I didn't see any thing.
    Dec 2010
    Fairfax Station, VA
    For checking vacuum leaks, crank the car up and spray some carburetor cleaner around the joints of vacuum lines and air intake boots. If you get a sudden surge in idle speed, then that's where your leak is.
    Bruce
    11 M3 - 1st son
    04 Tundra - 2nd son
    11 335is (8/17)
    01 325ci (3/12)
    05 ZHPci (7/11)
    03 330cic (2/11)
    00 323ci (10/10)
    Jul 2014
    Eastampton, NJ
    Thanks again Bruce. Right now it seems to be getting better each time I drive. I was chasing a lean condition for a while, so all the intake boots, F connector and CCV were replaced and the condition finally went away for good when I changed the fuel pump. I am going to drive it for a few days and see what happens. If I'm still having problems then I'll go to the next step you describe.
    Paul
    Damn I'm jazzed to have Bruce back!
    Sent from my Pixel XL using Tapatalk
    Jul 2014
    Sterling, VA 20165
    2004 ZHP Acquired: February 5, 2017
    Lorenzo's Project Thread
    Jul 2014
    Eastampton, NJ
    Here is the follow up to my post yesterday. After driving for a while I had the SES light come on so I knew I had an actual problem. I came home and checked the codes, they were P0171 and P0174. I am very familiar with these and now it was certain that I have an air leak somewhere. When I work on things and find a new problem I always go back to where I was working figuring the issue has to be in that area. That strategy paid off. As I was wrestling the oil filter housing back in place I must have moved the hose from the valve cover to the crankcase ventilation separator. It was disconnected from the separator. I managed to get my hands in there and hook it back up. Now it runs fine. Maybe I didn't have that hose well seated when I put it on over a year ago. You gotta love ZHPMafia. I get frustrated with a car issue, post something and people actually answer you. How can you beat that?
    Dec 2010
    Fairfax Station, VA
    Glad to hear that you found it, well done.
    Bruce
    11 M3 - 1st son
    04 Tundra - 2nd son
    11 335is (8/17)
    01 325ci (3/12)
    05 ZHPci (7/11)
    03 330cic (2/11)
    00 323ci (10/10)
    +1
  1. Don't fear the oil filter housing gasket
    By Sockethead in forum General -- ZHP Related
    Last Post: 03-25-2014, 04:29 PM
  2. Oil filter housing gasket leak. DIY?
    By 09mageec in forum Mechanical | Troubleshooting
    Last Post: 02-21-2013, 07:45 AM
  3. replacing oil filter housing gasket and VCG
    By rikdee in forum Mechanical | Troubleshooting
    Last Post: 05-05-2012, 07:03 AM
  4. Oil Filter Housing Gasket
    By rikdee in forum DIY
    Last Post: 04-04-2012, 10:47 PM
  5. Oil Filter Housing gasket.
    By xtremecro in forum General -- ZHP Related
    Last Post: 09-26-2011, 08:50 AM
