Results 1 to 10 of 10
    Beaverton, OR
    Fuel pump float sticking?
    I filled up today, and when I turned my car on to leave the needle only rose to half tank. This happened once before, except the needle didn't rise at all. Once I turn the car off, then start it back up, needle rises to full normally. Could this just be a lazy fuel pump float? This car sat for ~5 years prior to my purchasing it, maybe there is some old gas that gunked it up? Would something like Seafoam remedy this?
    2016 BMW M340i
    2013 BMW X5 M-Sport - Sold
    2009 550i M-Sport - Sold
    2006 650i Vert - Sold
    2004 330i ZHP - Dead
    2001 330i Sport - Sold
    2004 330i ZHP - Sold
    1999 E36 M3 - Sold
    VA/DC
    Mine is similar but it usually takes an hour or so to move all the way to full. I swapped pumps and my cluster and it's still the same. I'm thinking it's a voltage issue, but I don't know where the issue could be.
    I don't know how seafoam could help.
    Beaverton, OR
    Well shoot, hope that's not the case with mine. It's only happened twice, not a huge deal. I was thinking if there's a chance that the float arm on the fuel pump itself was sticking, that seafoam in the tank might clean it up.
    2016 BMW M340i
    1999 E36 M3 - Sold
    VA/DC
    The pump/float is pretty easy to pull out and inspect. What's your mileage? OE pump? Maybe swap it out?
    Boston Metro West (BMW)
    I'd swap the pump if it is original anyway.
    Patrick ///04 330i ZHP///BMWCCA#465139///Jim Conforti Shark Injector///H&R Touring Cup Kit///Gruppe M Intake
    Jan 2013
    Central California
    Quote Originally Posted by TheFinanceGuy View Post
    +1
    Could be a ground issue possibly.
    Beaverton, OR
    Just turned 95k, can't imagine the fuel pump goes bad under 100k miles? But as I said, the car was sitting for years, the PO (who is a BMW tech) said he did all of the standard maint for getting it up and running again. But I have a feeling i'll run into little bugs like this now and then. It only happens right after fill up, and it's only happened twice. Totally fine now. Fuel pump is relatively easy to get to and remove, so I may pull it out and inspect it at some point
    2016 BMW M340i
    1999 E36 M3 - Sold
    VA/DC
    Take the advice about replacing it or at least keeping one in the trunk...
    "ZHP is a garbage option anyway- just some cosmetic upgrades with a different cam and diff to claw back some of the performance lost fitting those hideous and heavy wheels. Any 330 with a 3.46 diff will smoke a ZHP every time. The whole Mafia thing reeks of childish behavior." - anonymous E46 fanatic
    Beaverton, OR
    That might be a bit overkill... Car has no issue getting fuel, it runs great and pulls very smoothly all the way through the rpm range. $150 isn't in my realm of "just in case" parts. I'll keep an eye on it and if things change I can go from there
    2016 BMW M340i
    1999 E36 M3 - Sold
  1. PSA: Fuel Pump Install (Fluctuating Fuel Gauge)
    By melonz in forum General -- ZHP Related
    Last Post: 06-11-2015, 04:44 PM
  2. M3 Fuel Pump
    By Raptorman5174 in forum General -- ZHP Related
    Last Post: 04-14-2015, 01:29 PM
  3. When to change fuel pump, fuel filter?
    By johnrando in forum Maintenance
    Last Post: 11-17-2014, 10:57 AM
  4. Fuel pump noise?
    Last Post: 02-27-2014, 04:29 PM
  5. Fuel Pump
    By GSEN820 in forum Mechanical | Troubleshooting
    Last Post: 10-17-2011, 03:16 PM
