Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 60
  1. #21
    May 2015
    Just west of Boston, MA
    That sounds very reasonable. I bet they have cookies in the waiting area too.
    BMW of Sudbury is really fancy, they also have croissants and cappuccino.
    Grab a cookie and coffee, then hoon the loaner.
    Definitely will, right after I put it in sport mode. I hate that they all seem to default to Eco+
    Sorry that didn't help. About 1 hour of labor sounds about right. I hope that sorts it.
    Not a problem! I appreciate the suggestion, always good to build a definitive list of what isn't the problem.
    Steve,
    2004 330i zhp
    2009 X3
    2013 X1 35i M-Sport
  2. #22
    May 2015
    I tried something today to try to better understand the different driving modes that the DME is programed for. I drove to work in D mode and was able to create the 2,800 rpm stumble every time. It is very noticeable in D. I drove half way home in S mode and the stumble is still there but much less pronounced. I drove the rest of the way in M mode and was able to floor it and click through every gear without any stumble at all. I wonder if when in D and S mode the DME goes into a sort of high speed cruise mode for better fuel mileage and perhaps goes a little lean, and in M mode it is instead always ready for you to ask it for more, and not worried about fuel mileage, keeping the fuel maps the same as in lower gears. Just an observation and some ideas. My brain is incapable of not trying to figure this out.
    Steve,
    2004 330i zhp
    2009 X3
    2013 X1 35i M-Sport
  3. #23
    Boston Metro West (BMW)
    Steve - let me how this goes. I'm having this issue as well right at the 2,800 mark. I've tried just about everything I can to get rid of it. Including sharking it!
    My DME was updated according to my local tech. I honestly never thought about bring it to BMW of Sudbury for this.
    BTW - will you be at their cars and coffee on May 7th?
    http://www.herbchamberscarsandcoffee.com/
    Patrick ///04 330i ZHP///BMWCCA#465139///Jim Conforti Shark Injector///H&R Touring Cup Kit///Gruppe M Intake
  4. #24
    Jun 2014
    Toronto, ON
    Quote Originally Posted by daytona90t View Post
    Your theory does make sense. I have similar observations - the 2800 stumble is less pronounced in M/S modes.
    I feel that in the S mode, the gears are held longer and it downshifts much more readily as soon as you hit the gas, the stumble is less noticeable. Haven't really tried to drive much in M mode to reproduce this issue.
    It might help if we have a member here with a automatic and the later DME version to chime in...
    anandoc
  5. #25
    Philadelphia
    Your DME is already on the latest software. 7561382 refers to the "program" version and 7561520 is the "calibration". 7561382 is the newest program available, and the calibration is likely one of the ZHP-specific ones already.
  6. #26
    May 2015
    Quote Originally Posted by TheFinanceGuy View Post
    I bring both the zhp and the X3 to Sudbury for small stuff that I can't or don't want to do myself, like alignments and the occasional oil change. I have found that this helps keep a good rapport going for when I need things like a DME update. It's also nice to get to drive a loaner one and a while. I didn't buy either car from them but they have been great and treat me like I did.
    I would like to go to the cars and coffee event, but I think that my wife has to work that morning and I doubt that I can get the 10 month old out of the house that early.
    Steve,
    2004 330i zhp
    2009 X3
    2013 X1 35i M-Sport
  7. #27
    May 2015
    Quote Originally Posted by terraphantm View Post
    If this is the case, do you know how to check the "calibration" version with either my handheld carsoft scanner or the P.A. Soft BMW scanner 1.4?
    I was trying to use RealOEM to verify the latest version and this is what I was able to find.
    For vehicles with Performance Package S767A=Yes
    01 RMFD control unit DME programmed MS45.1 03/2003 07/2004 12147561520
    12147561520
    Supersedes:
    12147542993 (09/01/2005 — 09/01/2005), Exchangeable retrospectively
    12147549087 (09/01/2004 — 09/01/2005), Exchangeable retrospectively
    12147548580 (08/01/2004 — 08/30/2004), Exchangeable retrospectively
    12147547799 (07/01/2004 — 08/10/2004), Exchangeable retrospectively
    12147546938 (07/01/2004 — 07/22/2004), Exchangeable retrospectively
    12147537241 (03/29/2004 — 07/06/2004), Exchangeable retrospectively
    12147540382 (12/01/2003 — 04/20/2004), Exchangeable retrospectively
    12147537792 (12/01/2003 — 12/01/2003), Exchangeable retrospectively
    12147536841 (08/01/2003 — 12/01/2003), Exchangeable retrospectively
    12147533695 (07/01/2003 — 08/08/2003), Exchangeable retrospectively
    12147532778 (05/01/2003 — 07/10/2003), Exchangeable retrospectively
    12147531907 (02/21/2003 — 06/10/2003), Exchangeable retrospectively
    12147531491 (03/01/2003 — 02/24/2003), Exchangeable retrospectively
    12147530214 (03/01/2003 — 02/18/2003)
    Part 12147561520 was found on the following vehicles:
    3' E46   (09/1999 — 08/2006)
    Steve,
    2004 330i zhp
    2009 X3
    2013 X1 35i M-Sport
  8. #28
    I bring both the zhp and the X3 to Sudbury for small stuff that I can't or don't want to do myself, like alignments and the occasional oil change. I have found that this helps keep a good rapport going for when I need things like a DME update. It's also nice to get to drive a loaner one and a while. I didn't but either car from them but they have been great and treat me like i did.
    Its a perfect for the baby! I used to bring them when they were little, not at 2 and 4 - they want to stay in bed - which I am not going to complain about!
    I use a shop near me for the stuff, for the same reason. He is/was a BMW certified tech that opened his own shop.
  9. #29
    Philadelphia
    12147561520
    Supersedes:
    7561544 is the so-called "New Jersey" flash which is why mine shows that instead of 7561520 or 7561522. Nonetheless, if your DME is reporting 7561382 (notice that matches my "BMWTNR"), you're on the latest software.
  10. #30
    May 2015
    Wow! That may be the most detailed response I have ever received on a forum, Thank you. I will check again this weekend and go into the "User info fields" to check my assembly number. I was honestly always terrified to drill into the "Reprogramming" under the DME section, lots of good info in there. Thanks again, I would hate to pay $145 for them to just tell me that I was already as up to date as possible.
    Steve,
    2004 330i zhp
    2009 X3
    2013 X1 35i M-Sport
  1. Bottom front plastic shield falls off on the highway SMH
    By Dathaeus in forum Mechanical | Troubleshooting
    Last Post: 02-17-2017, 10:09 PM
  2. Warm Start RPM Stumble
    By dml5055 in forum Mechanical | Troubleshooting
    Last Post: 03-21-2015, 06:09 AM
  3. Angeles Crest Highway Pics and Video
    By tripod06 in forum ZHP Gallery and Video Section
    Last Post: 06-28-2011, 08:03 AM
