Page 6 of 8 FirstFirst ... 45678 LastLast
Results 51 to 60 of 76
  1. #51
    Update: 2 shops have told me they suspect it's the top nut in one or both of the front struts. Unfortunately, getting access to this nut and putting everything back together + the alignment is a pretty large bill to test a theory.
  2. #52
    Lexington, KY
    Top nut can be tightened of checked very easily with a strut nut socket. It has an opening so you hold the center of the strut with an Allen wrench and tighten the bolt. Worth purchasing maybe.
  3. #53
    Shawty I got what you want I got what you need
    Swing by whenever and take it
  4. #54
    Amazing! I'll text you Nate - thank you.
    Is there anything else that could be loose in there (i.e. in the top of the struts)? It seems like the shop which came up with the confident "top of the strut" noise diagnosis would have been aware of this very easy way to test their theory without hours of work.
  5. #55
    Just realized that it's a simple spark plug socket with the rubber core removed. You may already have one?
  6. #56
    So it's a 13/16?
    Sent from my S8+
  7. #57
    So it's a 13/16?
    Sent from my S8+
    Yep. It worked when removing my OE struts, but it was too small for the nut on Nick's Bilsteins.
    We ended up throwing a 7/8" socket on a 1/8" impact driver and got it to tighten 1/4 turn without the strut spinning. Hopefully that was enough.
  8. #58
    Yeah. Mine is 7/8" as well.
    Sent from my S8+
  9. #59
    Noise is gone after tightening up the single nut on the top of the strut! As seen in the pictures above, no need to take out the strut to accomplish this in case others are trying to find a similar noise.
    Now I just need to figure out the seat squeak noise.
  10. #60
    Quote Originally Posted by nsk040 View Post
    excellent - love the easy ones.
    now, about the squeak... driver's seat, rear left corner?
  1. Replies: 24
    Last Post: 06-26-2016, 02:28 PM
  2. Need help finding clunk noise, possibly in suspension
    Last Post: 01-19-2015, 03:37 PM
  3. Differential Diagnosis: FCAB vs Wheel bearings
    By TigerTater in forum Mechanical | Troubleshooting
    Last Post: 02-28-2014, 07:28 AM
  4. Oil leak and Vaccum Leak: Help to diagnosis?
    Last Post: 01-08-2014, 11:41 AM
  5. Replies: 23
